Hey all! New Getaway owner here. I've been having a factory reset issue every time I turn the game on. I checked the batteries, checked the D2 diode, and checked to make sure power was getting to the RAM. Everything checks out. Most guides I've read stop there, as I take it the problem is usually in one of those places. Now, there is some bad corrosion damage on the board that is definitely causing some issues elsewhere that I'm working on, so I'm wondering if it could potentially be causing this?
I will be taking the board off soon to clean and check for all corrosion spots. Is there anything in particular I should look out for in regards to this issue? Thanks!
