(Topic ID: 274314)
Getaway HS II plunger stopped working
By Jasolution
7 days ago
  • 2 posts
  • 2 Pinsiders participating
  • Latest reply 7 days ago by LTG
#1 7 days ago
I have an HS II on which the plunger stopped working. Here’s what I’ve tested so far:
- I have 60v on both coil lugs
- On Q52 transistor, grounding it does not cause the coil to fire
- The Q52 transistor has a slightly higher resistance than the other transistors in its vicinity
- All wires are connected and good
- The up/down switch on the shifter tests good
At this point, is there any other test I can use to rule out the transistor? It seems that, based on my testing so far, the transistor has gone bad, but would like to confirm that before I pull the board and attempt to replace it.
Thank you!
#2 7 days ago
Ribbon cable between CPU and driver board good ?
$ 16.00
Trade
Machine - For Trade
Belfast, NY
$ 131.00
Cabinet Parts
Tilted Pinball
