Are the 555 flashers in the backglass of Getaway High Speed II 12 volt or 6.3 volt? I put 12 volt 5smd flashers in there and they are awfully dim. The 12 volt 555 flashers in the supercharger seem to be fine.
If you check the solenoid table in the game manual. Flashers that are 12 volt all seem to be on the playfield.
Didn't say anything about flashers in the backbox. If it's all GI lighting it would be 6.3 volt.
If the game flashes them, and doesn't burn them out instantly, they'd be 6.3 volts. #555 would burn out fast when 20 volt hits them, unlike a 12 volt bulb.
Quoted from LTG:If you check the solenoid table in the game manual. Flashers that are 12 volt all seem to be on the playfield.
They are flashing but very dim. They are 12 volt 555 bulbs that I put in. The FreeRide flasher underneath the playfield is also flashing dimly.
Quoted from Lpilot1:They are 12 volt 555 bulbs that I put in.
You mean you put 906 or 912 bulbs in ?
All 555 bulbs are 6.3 volt.
Both are wedge base.
Quoted from LTG:You mean you put 906 or 912 bulbs in ?
I think some flashers on this game are 555s aren’t they or did I miss something? Every flasher I bought is 12 volt.
Quoted from Lpilot1:I think some flashers on this game are 555s aren’t they or did I miss something? Every flasher I bought is 12 volt.
I don't have the game to check.
The manual lists flashers on the solenoid table that are 12 volt, they get briefly hit with 20 volts.
If you put a 555 bulb in a socket and it gets hit with 20 volts, it burns out instantly. If lit normally it's 6.3 volt socket. If you put a 12 volt bulb in and it's dim, then it should have been a 555 6.3 volt bulb.
#555 bulbs are all 6.3 volt. They don't make a #555 bulb in any other voltage. #906 or #912 bulbs are 12 volt bulbs, commonly used in wedge base sockets that get hit with 20 volts to flash brightly briefly.
I'm sorry, I don't know how to explain this any better.
Quoted from LTG:The manual lists flashers on the solenoid table that are 12 volt, they get briefly hit with 20 volts.
The names of these flashers and locations are listed on the solenoid table. None are in the backbox.
I might add I don't have the game to check.
In the backbox the game might blink some of the #555 bulbs, or someone may have put in some #545 blinking 6.3 volt bulbs.
There is a difference between blinking and flashing.
Quoted from LTG:I might add I don't have the game to check.
I understand what you’re saying. What Im saying is that I put in 555 base 12 volt flashers. See attached pic. I’m trying to find out if they’re supposed to be 6.3 volt instead of 12 volt. They are flashing very dim. The 12 volt bayonet base flashers on the playfield are blinding and normal. These aren’t. I can’t find anything in the manual. I guess I’m not looking in the right place. People really do this for fun? Lol!
E153CFA6-D837-4BEB-8E5C-F72436A7B460 (resized).jpegPretty sure the backbox is all regular 555 bulbs. I have 2 of these I keep running and I don’t recall any flashers in the backbox but I can look next time I’m there.
Quoted from Lpilot1:They are flashing very dim.
If 12 volt ones are dim, they aren't getting enough voltage. Likely 6.3 volts is what voltage is there.
Quoted from Jmckune:Pretty sure the backbox is all regular 555 bulbs. I have 2 of these I keep running and I don’t recall any flashers in the backbox but I can look next time I’m there.
Ok. Thanks!
Quoted from Lpilot1:What Im saying is that I put in 555 base
The 12 volt flashers you are pushing into the 555 sockets, are a little larger. And might hurt the socket or the metal clips inside the socket that grip the bulb.
These are both wedge base bulbs.
#555 6.3 volt T3-1/4 Glass Wedge Base
12 volt T5 Glass Wedge Base ( typically #906 or #912 bulbs )
Your picture is 12 volt wedge base. They are a tiny bit larger than a 6.3 volt #555 wedge base.
Most games have flashers in the backbox (also referred to as insert in the manual).
System 11 games generally use #44/#47 bayonet sockets for GI (6.3VAC). They generally use #89 bayonet sockets for flashers (12VDC powered by nominal 20VDC). The size difference in the bayonet sockets makes it obvious which bulb is which.
WPC games general use #555 wedge sockets for GI and #906 wedge sockets. The size difference is so similar that the sockets are a different color to differentiate them. The GI #555 wedge sockets are WHITE (natural). The flasher #906 wedge sockets are BLACK. You can also tell because the wiring servicing the flashers is RED-WHT for the power and BLK-*** or BLU-*** for the drive.
The exception to this is Pat Lawlor games that used either #44/#47 bayonets for #455 BLINKERS (not flashers) or #555 wedges for #545 BLINKERS (not flashers). The blinkers are powered using 6.3VAC just like the GI (in fact they are on the GI circuits).
I don't have a Getaway so I am using the manual (and assuming the manual is correct).
There appears to be five flashers in the backbox.
All the drive wires are connected to J125.
If you want confirmation you can take pictures of the backbox (from behind), one of the connector at J125 and post them here so the above information can be verified.
Quoted from DumbAss:Most games have flashers in the backbox (also referred to as insert in the manual).
What’s the difference in “Flasher” and “Special Drive”?
Quoted from Lpilot1:What’s the difference in “Flasher” and “Special Drive”?
The "Flasher" is a dedicated flasher circuit. There is no tieback diode on the power board. It must be a resistive load and implicitly it cannot be an inductive load (without a diode at the solenoid that would violate the pattern).
The "Special Drive" is a general purpose circuit. It can be either a flasher (resistive load) or a solenoid (inductive load). When the circuit is used as an inductive load a tieback wire must be used to connect the power (voltage) supply to the tieback diode that is present on the power board.
For your purpose (this problem) there is no difference as you are asking solely about the flashers.
This page was printed from https://pinside.com/pinball/forum/topic/getaway-high-speed-ii-backglass-flashers and we tried optimising it for printing. Some page elements may have been deliberately hidden.
