(Topic ID: 138228)
Getaway: help with ball lock coil locking on - CPU board at fault.
By LongJohns
  • 4 posts
  • 3 Pinsiders participating
  • Latest reply 4 years ago by LongJohns
#1 4 years ago
Gentlemen (and ladies),
I have a problem withe the ball lock coil locking on. I have narrowed it down to the CPU board (swapping boards) and looking for some further help or advise on narrowing it down some more.
History: at some point in the past the batteries had leaked on the board and that has been cleaned up and all the IC's below the holder have been socketed and replaced. GI lighting is intermittent - which is also a problem with this CPU board.
Now, from what I can gather from the drawings, it looks like either U20 (ULN2803A) or U4 (68B09EP CPU) can be the issues, but wanted to check here with someone that may have more experience at WPC CPU board repair than me on their thoughts (maybe I am out in left field?). Any comments on the GI lighting "section" would be helpful as well.
Thank you in advance for any help/suggestions.
#2 4 years ago
Did you check the transistor on the driver board?It could be shorted
#3 4 years ago
Quoted from LongJohns:
Is coil locking on because of an activated switch or is it randomly firing the coil (and GI) ?
If it is a problem with switches then check all of them in switch test T1.
Else check components in red circles for corrosion and/or re-seat them in their socket.
#4 4 years ago
Quoted from Cycloneman:
Thanks for your reply, but the problem follows the CPU board when it is moved to a different game - or if I install a different CPU board in the game it solves the issue(s). So it is not the ribbons cables or any thing else in the game.
Quoted from zaza:
Thank you for the reply, U12 has been replaced (new chip and I installed a socket) - pulled U4 and it looks ok and does U9. J211 seems to look ok as well. Granted I haven't tested the board in the game since reseating U9.
I did notice some thing a bit different when I was doing a quick check (bench testing) on U1 (pins 17 and 18) with a logic probe - will have to dig out the scope and look into this further.
Of note this isn't a hard failure, the game will play fine for a short time and either the GI lights will go out (usually at power up) or the coil will lock on - turn off and let it sit and power back on and sometimes the problem may have fixed itself. Haven't notice any other odd things.
One other thing is when I hooked the board up on the bench, it really seemed to load down the 5 volt line and had the adjust the voltage up to bring the level back up to 5 volts (went from 5.0 volts no load to 4.61 volts with the board powered) - not sure if this is because I am using a crappy power supply. Of course this could be because of a bad IC (or something).
Fort Lauderdale, FL
$ 28.00
$ 131.00
Cabinet Parts
Tilted Pinball
KAHR.US Circuits
$ 99.00
Pinball Sales
Metal-Mods
$ 135.00
LED OCD
$ 27.99
Lee's Parts
Vancouver, BC
$ 229.99
Gweem's Mods
$ 175.00
Professor Pinball
$ 40.00
PinWoofer
San Jose, CA
$ 399.95
PinWoofer
$ 109.99
3,000 (OBO)
Rutledge, PA
€ 3.70
