J120 is AC volts, so make sure your meter is set to that. It's used for GI lighting. If you have missing pins from what I posted, that's ok, just note it down when posting results.
You could put the TAF ribbon in Getaway.
Also, double/triple check that you have all the pins lined up correctly.
i quite literally got a job fixing pins @ an arcade way back in the day, by watching the manager attempt to fix a TAF, and pointing out "if you shift that cable over one pin, I bet it works" .... it did, I got to play the game (which is what I wanted in the first place), and he offered me a job fixing his games.
That led to 7 years fixing games at a distributor, and a longtime hobby.
Quoted from Kazak:J120 pin 7 fluctuates around pin 2VDC. and pin 8 fluctuates around 2.5CDV.
J120 is AC not DC, try it with your meter set on Volts AC.
Also, try out litz's suggestion, it might work.
Pull J102 (the secondary wire for the +20 and +50), and try the Addams cpu in the Getaway, see if the playfield lights and GI come up.
(if you disable the flasher/solenoid power, you basically turn the game into a test fixture; you can run any cpu software you want, and it won't damage anything on the playfield)
At this point, your issue is one of two things ... either the main buffer chip that feeds the data bus over to the power driver has failed, or the blanking circuit won't release.
I agree with litz. Let us know how the test turns out.
EDIT: Hmm, I just realized that even though I type the underscore in litz's name, it isn't showing up.
Have switched boards around and have found the culprit is the Getaway CPU board. Power driver assembly boards are all OK. What next?
P.S. Sorry it's been a while.
While I'm at it, after swapping the Power Driver Assembly boards in TAF and Getaway, I notice that lamp matrix column 8 (the T-H-I-N-G lights, the start button) is down on TAF (game plays fine on both PDAs, but with those lights not working). This would indicate that the TAF CPU also has a fault, yes?
Quoted from steve1515:Hmm... So, you put Getaway's Power Driver board into TAF and the THING lights didn't work? Is that correct?
That sounds like the maybe you have a problem with the power driver board (or the ribbon cable).
How did you determine that there was a problem with the CPU board?
First, TAF lamp matrix column 8 was dying slowly - light by light over a few weeks. When I swapped power driver boards, I still have the same problem on TAF but rest of game still works, therefor I assume that both power driver boards are OK (with J102 disconnected on Getaway and the TAF CPU installed, I get lights back on Getaway).
Clearer? So both power boards seem OK and each CPU seems to have a fault. I dont suspect ribbon cable, as swapping these gave same results. so... ????
Hmm... Could it be that both ribbon cables are bad? Maybe you could order one cheaply and try it out: https://greatplainselectronics.com/products.asp?cat=52
If I have time in the next few days, I'll take a look at the schematics and see if I see anything else to test out.
Hopefully someone else chimes in with some suggestions.
So, to recap...
You have a HS2 that has no lamps (GI and Regular) working and also doesn't have any solenoids working.
But, when you put in a TAF CPU, you get GI and Regular lamps working again.
Correct?
Quoted from steve1515:Hmm... Could it be that both ribbon cables are bad? Maybe you could order one cheaply and try it out: https://greatplainselectronics.com/products.asp?cat=52
So, to recap...
Correct?
That is correct. I appreciate your assistance. I doubt both ribbon cables would die simultaneously, but will retest to be certain.
Ribbon cables can be fault checked by reversing them ...
Most of the WMS ribbon cables are "signal" down one side of the cable and "ground" down the other side, so if you reverse both ends, you change all the "signal" conductors to the other set.
They DO go bad, too ... I've been to more than a few service calls where I look in the backbox, pull off the power driver ribbon, flip it over, plug it back on and the game works ...
!!! Just put Getaway back together and it's working! Don't know whether it was a cable swap or reverse or just some bad connection.
TAF is also working except for the lamps below the DMD ( *-T-H-I-N-G-*). The credit button light works which is the only other lamp on lamp matrix column 8.
Also the RPM lights below 3rd, 4th and 5th gear lights are not working properly on Getaway; they flash irregularly in attract mode and not properly during game play. I haven't spent any time looking into this yet as I have only just got Getaway going.
Thanks heaps to steve1515 and litz for patience and assistance.
I will check in to see if you have any ideas re these two remaining faults.
Should I put the TAF fault as a new topic in the TAF section do you think?
This page was printed from https://pinside.com/pinball/forum/topic/getaway-failure-involves-all-lights-solenoids-nut-not-dmd-or-audio/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
