I want to remove my diverter and tighten the rivets that are loose. This will really speed it up. My issue is my machine is a prototype and the playfield only swivels up and down, it doesn't pull out so you have to remove the playfield to get the ramp off. I can get to the set screw on the diverter though so should be easy. I completely removed the set screw and still can't get it out. Is it retained by a clip or something? Manual doesn't show one. Why can't I just pull the diverter out?
