So, while I am stuck without a plunger, I thought I would at least share my latest mods.
1. Replaced my 4 ohm woofer with 8 ohm, completely rewired speakers, added 80 ohm inverter and L-pad. For those of you who have not done this, it is great as I can now actually hear/feel the bass tones in the game. BTW, the L-pad was a must in order to manually balance the sound the way that was best for my ears.
2. Finished my homemade SC ramp sign and added green frosted LED in place of yellow. I like it much better as it catches my attention more during game play. Thought I would post a pick for others to consider.
3. Followed the guide in this forum and made my own custom LED lit flipper buttons. I used wedge sockets, various Matrix cables, and double red flex heads from Comet Pinball to do the job. Also, wired into start switch so they flash when pin is not in play mode and solid when it is. I'm trying various things (mainly black electrical tape) to help with the apron bleed through, but overall does not seem to be bad. Also, if you do this mod be aware that the spacing is very tight on the plunger side.
4. Finally, I wanted to "pop" the fluorescent orange a little more, so I installed some UV lighting upgrades. I added two Comet UV spotlight bulbs (http://www.cometpinball.com/product-p/6leduv.htm) to the back section to light up the back ramp and left loop (I previously had white bulbs installed here), I already had a 3 LED strip under my SC sign, and replaced my white frosted 7 LED strip under the apron with a 7 LED UV strip. The main upgrade I did was to add 2 UV spots to the sling gauges. This really makes the orange in center area glow. In my first pic, I have the apron UV lit, but not the 2 spots. In the second pic, I have the spots lit and you can see the difference it makes with the oranges with the Getaway logo, 1st-5th gears, and the tachometer. I'm sure that the UV effect is not for everyone, but I thought I would share in case anyone had ever wondered about it.
5. Since I now had a extra LED strip that I didn't know what to do with, I put it in the GI just behind the lower left targets. Wow, it really lights up the plastic (see the same photo where I have the UV spots - bottom left speed limit sign). Now I am thinking about buying a few more of the Matrix frosted white LED strips to light up the other dark spots in green plastics lit by GI.
