Been working on some touchup paint with the worst spots on my playfield, so I thought I would share my experience in matching colors. To begin with, I used Createx opaque colors as recommended by Vid in his guide. I also took advice from those of you in this thread. I will admit, I could have gone into a much more detailed restoration, but quite frankly I was not up for that. I just wanted to improve the worst spots and continue on with enjoying the game.
For my repairs, I needed to match black, bright blue, neon orange, and yellow for the areas I wanted to repair. Here is what I discovered given my playfield condition (which I would consider to be good pertaining with minimal, if any fading) and the Createx airbrush paints (I used a regular brush to apply and cured with a heat gun between coats)
- Black: Used the black straight out of the bottle
- Bright/Light Blue (inner line around Free Ride & other inserts): Mixed 4 drops Opaque Blue with 2 drops Opaque White and it was a dead on match for me
- Fluorescent Orange (outer line around Free Ride & other inserts): Mixed 15 drops Fluorescent Orange with 1 drop Opaque White and it too was a dead on match
- Yellow (stoplights): No matter what I tried, I could not hit this color. I experimented like crazy but could never achieve the every slight goldish yellow color. I finally gave up, tried decals and failed, and now I am trying stickers (I plan on covering with Mylar).
After curing all paint, I double top-coated with Createx gloss clear, rewaxed with Carnauba, and voila - a much improved look for my pin.
While my work is far from perfect, it is significantly better than what it was before. I may take some time later to work on the lines a little more around the Free Ride, but I did my best for now.
