Quoted from flynnibus:The ramp flap is supported by a pivot bar that must be removed from behind the backboard. It's just held on by a nut, which you must use plyers to hold the bar from the playfield side, then undo the nut from the backboard side. Remove that, along with the assembly that is the top of the ramp.
If memory serves, you need to undo the right wireform from the screw in the playfield near the lock area so it can be slid around and completely pull the supercharger loop away. Then the ramp assembly in the back corner can be accessed fully.. remove the screws holding it all down and to the sides.. and the bar under the ramp flap as described before.
That assembly is common for being hacked or bypassed and the flap fails and often isn't replaced.
Yes I can see that I will need to remove the wireform. I have two questions please.
1. As you can see in the last picture I posted, you can see the pivot bar wedged in the underside of the ramp in a bracket to hold it in. My question is, once I remove the wireform, all the screws and everything, is it even possible to just pull the ramp assembly "away" from the pivot arm and off the bracket? I was just trying to not unscrew the pivot arm. Will that be possible to just pull away from the arm to release the whole ramp assembly? Or pretty much the pivot arm has to be unscrewed no matter what? Sorry for the question but in the picture, it appears as if just pulling the ramp assembly away from the pivot arm will do the trick. What do you think?
2. If I must remove the pivot arm, when I put it back, will that cause ANY issues when I start a game? What I'm trying to say is: The arm pivot right now with the game disassembled is in the up position. If I remove the arm, the whole thing will problaly go down. Will this confuse the game or cause any problems because I messed with the position of the arm? Sorry but I just don't want to mess this up. Thanks!
