Quoted from Mr_Tantrum:Wow, that thread has some detailed restoration techniques. I was hoping to maybe plop down some black paint and call it a day (i.e. just looking for a temporary "fix" to color the bare wood). If I were to follow your model and use a high quality acrylic paint applied with a brush, what clear coat did you use and how did you apply it (brush, spray, other)?
Yeah, Vid is very detailed, he must do professional restorations...
I forgot that I did a very minor touch up a while back without putting the mylar on top of the area because it was not needed in the spot. I put a piece of plexiglass on top of the PF and mixed the colors so they would match.
I cleaned the area to remove any wax and/or dirt before priming it with a white primer.
I used a good fine tip paint brush that I bought at an art store so you wouldn't see brush strokes. I used good acrylic paints also from an art store (when shopping I learned that there are many grades of paint). Only use good paint because it dries the same color that it's mixed and shouldn't run or discolor when clear coated. I got clear coat and just brushed it on because the areas were so small.
The one photo is prior to sanding it with 800 grit sandpaper to level it out. Use automotive clear coat, that's what Vid recommended, not varnish or poly...
I hope that helps.
