New! Dark mode!
(Topic ID: 78179)
Getaway Club ~ Dispatch, run a make on license plate KINGPIN
By MrSanRamon
6 years ago
  • 10,866 posts
  • 427 Pinsiders participating
  • Latest reply 17 hours ago by kdunbar
  • Topic is favorited by 208 Pinsiders
Topic poll
“Which S/W Version do you use?”
  • L1 19 votes
    6%
  • L2 146 votes
    50%
  • L3 10 votes
    3%
  • L5 102 votes
    35%
  • P7 9 votes
    3%
  • C-C 7 votes
    2%
(Multiple choice - 293 votes by 292 Pinsiders)
There have been 3,351 images uploaded to this topic. (View topic image gallery).
There are 10866 posts in this topic. You are on page 45 of 218.
#2201 4 years ago
Quoted from Grinder901:
Here are the caps:
I have sampled a ton of cap LEDs but I'm liking the pop bumper LEDs from Comet:
I chose to match the led to the color of the pop but I also wondered how natural or warm white would look in the pops.
Lots of options out there bud. Good luck
Guess I was being too literal being new to pinball. So non-Williams toppers will fit the Williams poppers (i.e. the only difference is the styling)?
#2202 4 years ago
Yes sir, non Williams caps work. I had similar questions. I bought clear caps, the Williams real, yellow and red caps as well as the jeweled caps
#2203 4 years ago
Well I tested all my fuses, Jesus there are a ton, like 25 of them, and they all had continuity
#2204 4 years ago
A ton of fuses is a good thing, it's more protection for your machine but I'm confused now, are there still issues with the lights or is that resolved?
#2205 4 years ago
Quoted from tiltmonster:
Oh no it's resolved but I thought testing them all to make sure was recommended. I used a continuity tester. It lit up if there was continuity. There were only a few that to me at least, didn't seem to burn quite as bright
#2206 4 years ago
Oh no it's resolved but I thought testing them all to make sure was recommended. I used a continuity tester. It light up if there was continuity. There were only a few that to me at least, didn't seem to burn quite as bright
Its not really neccesary to check fuses for continuity unless something is not working. Whats very important to do though is to check the fuse values and make sure they are correct when you get a machine. You never know what others put value wise.
#2207 4 years ago
2 problems (connected?) (L2)
I keep getting "check top lock switch 74". It works correctly (as far as I can tell) during each switch test. Closed when closed, open when open.
Hitting the tunnel often results in an endless multiball that can last minutes. The machine keeps auto launching after drains.
Any thoughts>?
#2208 4 years ago
Quoted from kilmarnock1350:
Any thoughts>?
The machine will show an error if a switch isn't used after a certain amount of time but it will still function correctly. Go into test, T3: single switch and enter, cycle through to top lock switch 74, wiggle or hit the switch lever a few times until you hear it beep to clear the error. The switch is located on the right side, in the wire form ramp under the "Donut Heaven"...
I'm not sure what your other issue is, multiball will give you "Free Ride" lit for a certain amount of time but I think I would need more info on what's happening.
#2209 4 years ago
duplicate
#2210 4 years ago
Has anyone every inventoried or had access to a list of hardware used on the playfield (i.e. screws, nuts, washers, etc.)? Most of mine are in bad shape (highly oxidized to the point that it takes away from the overall appearance) and I want to replace them. I just acquired the pin, and am doing some updates along with cleaning/waxing. If I was going to take everything apart a section at a time anyway, I hoping to be prepared ahead of time to put it back together with new hardware.
#2211 4 years ago
Quoted from Mr_Tantrum:
Not to my knowledge NO, but you also have to bare in mind that over the years since these machines came from the factory people have lost/changed screws etc, and not always used the correct size. Some sizes may have changed due to the holes being flogged out so a larger screw has been used. I've seen some bloody dodgy examples of things being used for the original part in some of the machines i've had (pretty sure most peeps have too).
#2212 4 years ago
Does this help? http://mirror2.ipdb.org/files/1000/Williams_1992_The_Getaway_High_Speed_II_Parts_List.txt
I'm not sure if it's 100% accurate, but it looks pretty detailed.
#2213 4 years ago
Quoted from steve1515:
Yeah, you're not kidding!
#2214 4 years ago
Any thoughts>?
Like tilt said, the game will report a switch error if that switch has not been triggered during several games. I would check all the lock and trough switches. Maybe do a factory reset. Don't know what would cause an unlimited ball save.
#2215 4 years ago
Free ride bug on L2 will do it
#2216 4 years ago
Okay, that's a lot of screws. Guess I need to try to figure out what is what, and how to decipher the coding.
Thanks for the reference.
#2217 4 years ago
Yes just the knob. You use the shaft you already have. It was a bitch to get the original knob off:
I just ordered one of these. Referring to the knob, how did you end up removing it? Did you just cut it off, did you try heat, some other way? Anything else from your experience that would be nice to know before attempting upgrade on my own?
#2218 4 years ago
I've got one more shipment of pop bumper parts arriving (new bases, and metal rings and new springs) and then I'm going to tackle the pops.
These goodies arrived:
The perfectionist in me is annoyed that I didnt opt for the dark green skirt instead of the lighter green. Any chance anyone of you has one I can buy?
John, you gonna place an order anytime?
I was wondering of the light green is actually "teal" when ordering? I am ordering a bunch of stuff from PBL, and this is the only one I see. Shows light green in photo of choices, but only "teal" in drop down selection (I would be happy with light green, but don't want to end up with a bluish-green).
#2219 4 years ago
Brother it was a major pain in the ass. I took a hack saw to it as well as a Dremel. I cut it in half all the way around with the hacksaw and then cut it vertical with a Dremel. I'm sure there is a smarter, easier way but I'm no rocket surgeon.
The light green is def green. Not teal. I had a hard time finding a dark green skirt. By the time I did, I already had installed the entire green pop assembly and I'm satisfied with it. I have the dark green skirt in a box filled with clear, red and white bodies and a ton of cap colors.
#2220 4 years ago
image_(resized).jpegimage_(resized).jpegimage_(resized).jpegimage_(resized).jpegimage_(resized).jpegimage_(resized).jpegimage_(resized).jpegimage_(resized).pngimage_(resized).pngimage_(resized).png
Well, my shifter just arrived but it does not work. Did not come with instructions on how to change battery. I removed the cap, but just contains the switch as far as I can tell. Searched the web, but cannot find instructions. Any guidance on how to replace batteries is greatly appreciated.
Even with all the work, based on your pics the end result looks well worth it. I was wondering what those shards of black mess were in your photos - Dremel & hacksaw at work?
#2221 4 years ago
Yep, all that black crap is shards of original shifter knob. There are several small Allen wrench type of screws in the center of the new shifter. Remove the screws and I'll bet you'll find two dead lithium batteries. Replace them and your good to go.
Here's an image of the dark green skirt next to the green pop
#2222 4 years ago
Also, this will def help:
#2223 4 years ago
i just noticed that i can start a game before the multiball locks drain, which causes my game to go in search mode. pretty annoying. is that fixed with newer software maybe?
#2224 4 years ago
2 of the screws are for securing the button at top, the other 4 are faux. When removed, I have nothing inside that points to where a battery should go (I've put batteries in thousands of devices over my long life, but this thing has nothing even resembling battery leads inside of it). The packaging looked like it had been opened before even though sold as new (also no batteries were included even though package said they were), so I'm thinking something is missing and I am going to exchange - 2 more days of waiting . . . bummer!
#2225 4 years ago
Just finished a DYI of the apron graphics. When I got my pin, the apron graphics were shot (all faded to a light pink, could barely make out the "W" logo, etc.) While I found some vinyl stickers online for $30+ s&h, this was a little more than I wanted to pay. My solution was to carefully measure everything then redesign by hand in Photoshop (probably better suited job for Illustrator, but my PS proficiency is far superior). Once designed, I printed onto high gloss ultra photo paper on my Epson 6 color inkjet then cut out everything with a paper cutter (straight lines) and by hand with scissors (curved lines). After cutting, I ran a fine pointed black Sharpie around all edges to cover the exposed white edges of the paper. Finally, I put some double-faced tape on the back around all edges and in center of each graphic, cleaned the apron well, and then stuck everything in place on the apron. I think it came out well (even tough I did not do color match exactly, I'm happy with how it looks), and I saved myself $30+ even though I had to put a couple of hours of labor into it.
See pics below for before & after. Graphics included: center Williams logo (4x6 paper), right apron triangle (5x7 paper), left apron triangle (5x7 paper), right apron horizontal lines (8.5x11 paper), and left apron horizontal lines (8.5x11 paper). I also printed both cards on the same printer using high quality photo paper.
PM me if you like, and I'll be happy to provide you with the Photoshop files I made for you to create your own graphics (if you don't have PS, I can convert to high quality PNG, JPG, PDF or whatever other format you may need).
#2226 4 years ago
Your apron is a huge improvement.
Two lithium batteries sit stacked on each other to power the shift knob mod. I'll see about taking the knob apart tomorrow for you.
#2227 4 years ago
VERY nice.
#2228 4 years ago
Nice tantrum! Apron looks sharp! I really like your cards, too.
#2229 4 years ago
Quoted from jawjaw:
Thanks. I got cards from here: http://www.pinballrebel.com/game/pins/instruction (slight change of size required), but everything else was my work.
#2230 4 years ago
Also, now that I'm thinking of it. I don't know that I bought my green skirt from PBL. I think I got it from Pinball.center so I can't really say what tint that green/teal skirt is going to be. I would email Terry and ask him at PBL before wasting the money.
Ryan
#2231 4 years ago
I love to mod my pin but I usually only do things that can be easily reversed... I just worry if I ever have to sell it (I'm actually thinking of this now, please tell me if I'm crazy) the buyer may want it stock.
#2232 4 years ago
Nothing against those that have done the shifter knob mod, but it looks pretty "ricey" to me. I'd rather have the stock one.
Also to answer the guy about locked balls and starting a new game, L5 won't let you start a game either until all the balls are out of the locks.
#2233 4 years ago
Quoted from weaverj:
Same happens to me. I just trained my self to wait a second after the game... Let me know if you figure something out!
#2234 4 years ago
Quoted from Slim64:
I am running L5 and if I hit the start button quickly after a game my machine goes into search mode as well.
#2235 4 years ago
Quoted from jdb9294:
exactly. there's a few secs between the time the lock releases and the balls get registered in the bottom trough that this happens.
if l5 does it, that makes me sad.
#2236 4 years ago
Okay, I used this as a reference & did a visual/manual inventory of what I wanted to change on top. I think I got everything I needed ordered and some stuff came from local hardware store, but my conclusion is that whoever owned Williams at the time must have had a brother-in-law who owned a fastener business (i.e. did they really need to use that many different types/sizes of screws?)
Thank you for the reference, as it was very helpful.
#2237 4 years ago
Quoted from Slim64:
Hmm, while the comment may be a passive trolling attempt, I am going more after spaghetti than rice given the theme of the machine . . . vroom, vroom!
#2238 4 years ago
Probably 2 kinds of opinions here: 1) the purist and 2) the modder. Personally, I plan on enjoying my machine for years, and I want to put my own creative touches on it to make it unique as long as game play is not adversely impacted. If you are looking at the machine as an investment and plan to own it for a relatively short time then I would say keep it original along with any restorations being accurate to how the machine came. If you are like me, and plan to put it in your game room for years to come (maybe forever), then customize it, enjoy the projects while learning more about the machine, and have fun playing regardless of what anyone else may think about it. Just my 2 cents.
#2239 4 years ago
I could be wrong but i read it as a typo and thought he meant Dicey
#2240 4 years ago
No trolling at all. Just my personal opinion on how that shifter mod looks
now, if you had a Hurst shifter ball on there I'd be loving it.
#2241 4 years ago
For my 2 cents worth though, lol. Although i do like the look of the shifter knob mod (ahmmm that sounds kinda rude ) , if i was going to add that to my machine i would prefer to make up/ have made up a new shaft (as is mentioned in the instructions) for these 2 reasons >> A) using the original shaft and destroying the plastic part is completely NON reversible and B) those things just aren't available any more (at least not as far as i know).
#2242 4 years ago
Quoted from Slim64:
I hear ya. To each their own. The game is all about pushing limits and putting the pedal to the metal. That knob is boring and stock. But some owners, hell prob most owners, like their games the way they came. I like going over board and over the top, in case that wasn't already apparent.
#2243 4 years ago
Quoted from Mancave:
No he meant ricey which kinda denotes those rice cars/suped up Fast and the Furious type of cars. Hell I think anyway. Nothing offends me but is that term, ricey, because mostly Asians love those type of vehicles?
#2244 4 years ago
Ya haven't done this yet Grinder
#2245 4 years ago
Hahahahaha!! Maybe even too much for me. I plan to use actual lighter fluid and real flames on mine
#2246 4 years ago
LMAO and bring out the marshmellows on a stick too.
#2247 4 years ago
And guys, I feel like at times, I'm posting too much in the thread. Just excited and love sharing with people who share a similar interest. Once the game is back together and I'm playing it, I'll be too busy to post, I promise.
#2248 4 years ago
Agreed, do what makes you happy.
#2249 4 years ago
For those of you have done a speaker upgrade, is it really worth it - i.e. is the sound noticeably improved? Can you describe the difference you hear, or better yet make a recording available? I am considering a low cost 1 for 1 replacement of back glass speakers and cab speaker per earlier in this thread.
http://www.parts-express.com/pyle-wave-plx32-3-1-2-coaxial-speaker-pair--267-770
http://www.parts-express.com/prv-audio-6mb200-4-6-1-2-midbass-woofer-4-ohm--294-2703
btw, how do you get La Grange out of your head for at least 24 hours after playing this pin?
#2250 4 years ago
Not sure what a real Lambo shifter would cost me, but I can't imagine it is cheap.
$ 109.99
