(Topic ID: 78179)
Getaway Club ~ Dispatch, run a make on license plate KINGPIN
By MrSanRamon
6 years ago
  • 10,522 posts
  • 396 Pinsiders participating
  • Latest reply 21 hours ago by daveddd14
  • Topic is favorited by 186 Pinsiders
Topic poll
“Which S/W Version do you use?”
  • L1 18 votes
    6%
  • L2 140 votes
    50%
  • L3 9 votes
    3%
  • L5 97 votes
    35%
  • P7 8 votes
    3%
  • C-C 7 votes
    3%
(Multiple choice - 279 votes by 278 Pinsiders)
There have been 3,221 images uploaded to this topic. (View topic image gallery).
There are 10522 posts in this topic. You are on page 211 of 211.
#10501 5 days ago
Quoted from pacman11:
Okay yes, I am getting the same voltage on the backside of the board as the front. I tired soldering it differentLy to see if it would work by switching the wires to the other positive and negative sides of the battery. Regardless it’s doesn’t work..
Pulled this from pinball repair guides. Some other things to check now that you know the board is getting battery power.
Is Power getting Past the Battery Holder? (bad diode D2 or RAM U8)
If the battery holder is OK, next check to see if power it getting past the battery holder. Find CPU board diode D2 (1n4148, all WPC revisions); this is a small glass diode, right next to diode D1 (1n5817). To find D2, on WPC-S and prior, look to the right of the big square chip U9. On WPC-95, look just below the battery holder. With your game off and new batteries installed, put your DDM on DC volts and put the black lead on the backbox ground strap. Then put the red lead on diode D2 on the CPU board. The banded side of the diode should show about 1/2 volts less than the non-banded side (which should be about 4.3 volts). If only one side of the diode shows voltage, or both sides show the same voltage, this diode D2 is bad. Diode D2 is a 1N4148 or 1N914 diode. The D2 can be replaced with a 1n4001 in a pinch (the 1n4148 or 1n914 is a 'faster' diode, but in this situation a 1n4001 will work fine.) Note that diode D1 is a 1n5817, which has a low .2 volt forward voltage drop. In a pinch a 1n4001 can be substituted here too (with a .4 volt forward voltage drop, not quite as much power gets to the ASIC/RAM when the game is turned on). But using a 1n5817 gives the game better power management to the RAM/ASIC when the game is turned on.
Next test for voltage at the CPU U8 RAM chip (all WPC revisions). With the game off, you should get about 4.3 volts DC at pins 26, 27 or 28 of chip U8. If you don't, the battery voltage is not getting to the U8 RAM chip, and the game will boot up with the "Factory Settings Restored" error. Note pin 28 of the 28 pin U8 chip is in the same position as pin 1 of the chip, but on the opposite row of pins. Pin 1 is designated with an impressed "dot" right on the top of the chip.
There can still be problems even if a new batteries are installed and all the voltages check out. If the game is still giving "Factory Setting Restored" or "Set Time and Date" errors, there may be a bad CPU U8 RAM chip. This does happen where a bad U8 RAM will suck the life out of new batteries, causing them to go dead in one to four weeks. But make sure to double check that battery holder. Even minor corrosion can cause this problem. The voltages may all check out, but the corrosion may be enough to limit CURRENT, and cause this problem. The U8 RAM chip is a 6264-L or 2064 RAM chip.
#10502 5 days ago
I don’t see any damage to the board. Here’s a picture of the board by the battery area.
Correct it doesn’t storage the settings after I save them.
There is some battery damage on the resistors at R31. Not sure if the chip below those resistors has anything to do with settings memory?
#10503 4 days ago
Got this idea from another post somewhere, but thought I'd give it a try. However, I upgraded to the Comet 20 SMD strip (10 SMD was recommended). Gives some nice backlighting on the wall. Position pic is actually on my JP, but on my Getaway I adhered the light strip to the top of the cabinet.
#10504 4 days ago
I've had Comet frosted LEDs in my SC sign for quite some time, so since I was placing an order for other things I decided to try their non-ghosting faceted bulbs (yellow & red): https://www.cometpinball.com/products/faceted-non-ghosting. I actually like these better with the clear dome instead of the frosted white, and they are quite bright.
#10505 4 days ago
For those of you who have been missing out on the greatness of PinSound, now is your chance (I just received this promo email):
Hundreds of machines everywhere, thousands of pinball friends, a fantastic venue in Texas, ... It should have happened this weekend. A huge shoutout for all the hard work and effort done by the TPF team! For every order placed from Friday to Sunday on our shop, we will donate 5% to the Texas Pinball Festival to help them recoup their costs and investments.
For now, as we all have to stay safe, here are our special deals from our virtual PinSound TPF booth:
buy 1 PinSound Ultimate Pack and get free shipping on your order - coupon code TPF20ULTIMATE
buy 1 PinSound+ sound board, get 1 Headphones Station for free - coupon code TPF20HPS
buy 1 DMDLux, get a No More Reset for free - coupon code TPF20LUX
Deals only valid from Friday 27 to Sunday 29 March
#10506 4 days ago
Quoted from Mr_Tantrum:
The headphone station is absolutely essential for The Getaway.
#10507 3 days ago
Working Orange X pin replacement dmd for sale if anyone needs /one spare. Comes with gasket and filter.
37B66112-0AA6-4BE4-B0C2-F3470DC8C0CE (resized).jpeg66FEB279-D072-4EBB-99EC-E9DC2580EC08 (resized).jpegFD553AF1-DADF-4E6A-81DC-4D1EFD3E2FD6 (resized).png
#10508 3 days ago
What would cause a flipper to get weaker and weaker as you play? My left flipper starts out strong then after an hour of play it gets weak..
#10509 3 days ago
Interesting, I have the exact same problem with my Data East GnR. Been trying to figure it out for a while. I think my issue is related to power to the flipper. Does it move slower?
#10510 3 days ago
Quoted from pinballjah:
Yeah it moves slower for sure..
#10511 3 days ago
Well one good thing that came out of this is I finally have my getaway done. Titan Rubbers, Comet LED’s, LED flipper buttons, trough LED strip, and a few stickers.
Question I never looked into before, what does everyone do with their old incandescent bulbs? I have about 250 of all types from two machines.
2C5DFA54-A34A-485C-8B42-D9AB99A66292 (resized).jpeg380949B0-220C-4381-8E85-8634BF3C59AE (resized).jpeg7A0BC7C9-9305-48DA-9392-446FA50FE2B0 (resized).jpegCC6AE388-B7B5-473D-BF37-B1E2CA98EF8C (resized).jpeg
#10512 3 days ago
Quoted from daveddd14:
One use is to use them to protect light sockets when painting a backpanel.
#10513 2 days ago
Question I never looked into before, what does everyone do with their old incandescent bulbs? I have about 250 of all types from two machines.[quoted image][quoted image][quoted image][quoted image]
Very nice and clean looking Getaway!
As far as incandescent bulbs, mine all sat in a box for about two years in my walk-in attic until I cleaned stuff out a few months ago and they all went in the trash.
#10514 2 days ago
The cabinet is a bit rough but the playfield (diamond plated) is in great shape and now is playing super fast that is is all cleaned up!
#10515 2 days ago
Even though as many of these pins were made as there were (13,259 of them), it is pretty seldom that the cabinets aren't beat up or at least terribly faded.
#10516 2 days ago
Looking for a topper/siren for my getaway if anyone has one!
#10517 2 days ago
Quoted from Brich:
You mean the beacon light? If so, do you just need the red plastic dome or the entire assembly (motor, dome, etc.)?
#10518 2 days ago
I need the entire assembly!
#10519 2 days ago
Quoted from Brich:
I think pinball spare parts Austrailia has a used one for sale, unless it sold already
#10521 22 hours ago
I'd want to make sure your EOS switch is clean and adjusted properly, it is key to minimizing overheating of the coil. Just fixed a game here last night with that issue. Coil gets way too hot and loses power.
#10522 21 hours ago
Can anyone tell me how this post attaches to the playfield?
POST - STAR DOUBLE CLEAR 1-1/16 INCH TALL
#03-8247-13
Star double clear post 1-1/16 inch tall common to late model Bally and Williams pinball machines.
Requires 2 rubber rings.
Reference:
03-8247-13
Substitute for 545-5209-01
Weight: 0.11 oz
G-Money Mods
