(Topic ID: 78179)
Getaway Club ~ Dispatch, run a make on license plate KINGPIN
By MrSanRamon
5 years ago
  • 9,910 posts
  • 369 Pinsiders participating
  • Latest reply 1 day ago by JDHHoover
  • Topic is favorited by 171 Pinsiders
Topic poll
“Which S/W Version do you use?”
  • L1 17 votes
    6%
  • L2 138 votes
    51%
  • L3 8 votes
    3%
  • L5 93 votes
    34%
  • P7 7 votes
    3%
  • C-C 7 votes
    3%
(Multiple choice - 270 votes by 269 Pinsiders)
There have been 3,043 images uploaded to this topic. (View topic image gallery).
There are 9910 posts in this topic. You are on page 198 of 199.
#9851 32 days ago
Quoted from Mr_Tantrum:
No, you will need the new version. As of a week or so ago, all of my orchestrations on the PinSound community site are now in the new format. Just re-download and install.
Thanks, I think I realized what I did. There are two files available when you click the download button and I picked the wrong file.
#9852 31 days ago
Quoted from Sleepy:
This is the only one like that. I’m trying to get them to clean up for me.
#9853 30 days ago
To anyone who has built a pinduino supercharger DIY kit have you found the need to trim the LED strip? I get some of them lighting, but not all in the length. The voltage at the end of the strip seems to be more than adequate with 4.81v being read.
Also, any tips for placing that LED strip inside the ring?
#9854 30 days ago
Quoted from sparksterz:
Yes, you trim it to length. I didnt have any issues with the entire strip lighting. For placing it inside, I put it flush with the top of the trough, and verified clearance with a ball. It was a very easy install.
#9855 30 days ago
Quoted from robertmee:
Ditto. The LED strip should have cut lines on it, if I recall. I assume you purchased the LED strip with the adhesive backing? If not, you are going to need to use some double-sided tape (Scotch permanent will work well). Also, be sure to clean the inside top of the SC loop with alcohol before applying strip to ensure maximum adhesion.
When you say you got part of if lighting, how did you do that? If you actually ran it live with the Getaway program, the program only defines the first X number of LEDs (I don't remember exactly how many, and not where I can check it). This may explain why not all of the SMDs are illuminating on the uncut length.
#9856 29 days ago
I have it running right now by having the kit fully assembled and installed in my machine. I thought I had broken something, but in assembling an entire duplicate kit I get the same behavior which leads me to believe that my run of LEDs is just longer than the software works with. I haven't actually measured it out to see where the LEDs that are lit would line themselves on the inner track yet, I'll probably be doing that next and routing the wires.
#9857 29 days ago
The software will work with any # of lights (well, there is probably some limit). However, in my Pinduino Getaway program, I define the specific number of LEDs as 47 (must be the case that you define the number for the various running effects, etc. to work properly). My question would be if you cut where the lights stop working, would that leave you with 47? Also, is that the correct length to apply around the SC loop since it was for me and others?
#9858 29 days ago
Ah, yeah I just counted and my strip is definitely more than 47. That would explain it. Thanks!
#9859 27 days ago
Wow, feeling dumb right now...if I had just sized out the outside loop of the super charger with the LED strip in the first place it should have been obvious the amount of lit LEDs.
I did get it installed, I had to raise my strip just a hair above flush, but man is this a cool mod! Wish I did it years ago. No time like the present though!
#9860 27 days ago
The DIY kit is definitely the best bang for buck mod to this game.
#9861 27 days ago
Awesome, and glad you like it! Are you using my program or the default one?
#9862 26 days ago
I'm currently using your program. Only thing I wish I could change is to remove the idle animation from the video mode, by I'm guessing there's no way to read the signal for that.
#9863 26 days ago
Yeah, all of the events are triggered off of flashers. Would takes some additional hardware/connectivity development by Pinduino to anything beyond that.
#9864 24 days ago
So here is the recent addition to my Getaway: The CPR backglass. It not yet installed due to the old trimming being to tight for the 4mm glass. I will need to purchase the 3/16 " version and see how to make that work.
The colors are brilliant and the mirror looks very nice.
One drawback is the position of the image on the glass. It sits very low, so where the bottom will be covered by the trimming, the top will show a gap. Being completely honest - if it was not international shipping I would likely have it exchanged for this reason. But then again - I'm a perfectionist.
#9865 24 days ago
Quoted from Sprudeldudel:
One drawback is the position of the image on the glass. It sits very low, so where the bottom will be covered by the trimming, the top will show a gap. Being completely honest - if it was not international shipping I would likely have it exchanged for this reason. But then again - I'm a perfectionist.[quoted image]
I bought the mirrored one a year to 2 years ago, cant remember it's been so long. This was before they changed the printing process and I really like it a lot. The colors are awesome but it's their version of the BG...
I bought the budget EATPM BG and it's really good too but I wish I had gotten the mirrored one when they had it available. Still a great upgrade, enjoy!
EDIT: you can see a bit of the light bleed on the Elvira because it's not 100% centered but it's still beautiful!
#9866 18 days ago
I'm happy to present the Getaway Mountain Mod 2.0, now available for order on demand. Personally, I've never been a fan of the original mountain mod, as it just seemed too bulky and it kind of eats up the back right part of the playfield. Several months ago mjenison posted about a mountain he was working on, and I really liked his design and approach. He was nice enough to allow me to provide my input on the design as he progressed, and as a result we've decided to partner together to offer this mod.
This mod includes the following:
- Custom designed 3D printed mountain
- Internal lighting (LED strip with wiring and connectors to link into GI)
- Custom designed 3D mountain clear plastic to replace OEM version (cutout to allow for better view of mountain)
OPTIONAL: Spotlight with LED bulb and wiring with connectors to link into GI
Pricing is as follows:
- Mountain with internal lighting and custom clear plastic for supercharger loop = $100 (includes US shipping - outside US on a per quote basis)
- Spotlight with LED bulb and wiring: Add $10 to your order.
As always, PM me if you have any questions or would like to order. This and all my other Getaway mods can be found here: http://thezumwaltfamily.com/getawaypinball
Tunnel with Internal Lighting
Custom Plastic
With Spotlight
Without Spotlight
#9867 16 days ago
Wow, I'm really surprised by the responses I've received for the mountain mod. Just to let everyone know, I'm making them in the order I receive, so please be patient. I have lighting on order, and I'm researching how much it would be to have the plastics professionally produced. If cost prohibitive, then I will just make them by hand like I do all of my others. As a FYI, each mountain takes 24 hours just to print, then I have to paint the snow on top which is 3-4 coats but dries fast.
Also, I forgot to mention that the mountain I show is a darker brown than what the final versions will be. All I had at the time was a dark green filament, so I spray painted the mountain with whatever color brown I already had. The ones produced for sale will actually be more of a milk chocolate brown that is a much closer match to all of the brown on the plastics in the game. If you've ordered from me, and prefer the really dark brown (eventually, when I get a chance I'm actually going to replace mine with the new color), please let me know and I'm happy to paint your that color. I've attached a pic showing my first production mountain to give everyone a sense of the mountain color.
#9868 15 days ago
First mountain just finished printing. Four more to go to finish out this first batch of orders.
#9869 15 days ago
First mountain just finished printing. Four more to go to finish out this first batch of orders.[quoted image]
That does look like a mound of chocolate....yummy
#9870 14 days ago
Im putting that on wonka
#9871 13 days ago
I have some news for those of you who have purchased the new mountain mod 2.0. Honestly, one thing I was dreading was hand making all of the plastics that I decided to include with the mountains. I even ordered the material, but when I got it I realized I ordered the wrong thickness. So, I sent it back and that got me thinking about having the plastics professionally made (I've already handled the design work). Anyway, I have a fair quote from one place already, but today I also discovered a local company about 20 minutes from me that does this kind of work all the time. I should have their quote tomorrow so that I can make a decision who to go with. While it will definitely be a little more in cost (probably about $5 extra per order than I expected), I'm happy to absorb that. You will receive a professionally cut plastic, and I get to save hours of time working while sweating in a hot garage and getting plastic dust all over the place.
The lighting and wiring for this first batch of orders should be here by this weekend, so I think if things go as planned then I'm looking at mid-late next week for shipping out the entire first batch. After I finish these, I have some other orders to fulfill since these are consuming all of my print time, but after things clear up I'll be ready for some one-offs for those of you who may still be on the fence waiting to see how they look in everyone's games.
Just rolled #3 off the printer & starting #4. FYI, for those who thought I might be exaggerating, look at the print time remaining on the printer's LCD screen for this model that I just started.
#9872 12 days ago
So I've posted a few times over the last couple of years about ideas of how to fix my coin door holes. People shared some ideas, but nothing offered was something I wanted to undertake. As a result, I've gone on with life being bugged by it every time I play the game or even walk by the machine. I don't know why it didn't hit me sooner, but I tonight I figured why not make a decal to cover that area? . . . so I did. Not sure if this is a unique problem to me, but if anyone else is interested in the decal I will sell it for $10 shipped to US (pm me if interested).
#9873 11 days ago
I have the exact same problem. More pinball money
#9874 8 days ago
Thought I would give a brief update to all of you mountaineers (i.e. those who have ordered the Getaway mountain that mjenison and I are offering). Anyway, the initial batch is up to 8 and I've literally spent the last 8 days doing nothing on my printer but generating mountains. I'm on my second spool of brown filament, but thus far every print has come out perfect.
I've also been struggling for an entire week to get a couple of quotes on making the custom plastic for me that I'm including with the mod. I finally received all of the info today that I needed to make a decision, but it was already after 5:00 when I contacted the supplier with my intent to move forward. Hopefully, I'll get a confirmation tomorrow and an idea of what the timeline will be. Once I know, then I will let the group know as this will be the deciding factor for when I'll be able to ship out mountains to everyone who is in this initial batch.
Finally, I have all of the lighting ordered, but for some reason the post office is taking there sweet time. Package should have been here last Friday, but it's been sitting in some postal warehouse here in town instead of making its way to my house. This has happened before, and I'm confident I will receive the lighting before the plastics make it too me, so we'll be okay there.
To everyone else who has ordered 3D items besides mountains, you are next in queue and I should be able to get started on your stuff sometime on Wednesday. I'll make everything as quickly as I can, but realistically I'm probably looking at early next week before I'm able to ship all of the current orders.
#9875 8 days ago
was tere a photo of that somewhere? did i miss it?
#9876 8 days ago
View the pics here: https://pinside.com/pinball/forum/topic/getaway-club-dispatch-run-a-make-on-license-plate-kingpin/page/198#post-5226898
It replaces the original mountain plastic with the graphic on it.
#9877 8 days ago
Ahh... The clear one. OK, that makes sense.
I was thinking about the one the mountain sits on. Because there I have a problem. I'm using pinbits' protector plastics which are adding thickness. This results in the nuts barely biting into the threading on the posts. Considering needing to put the mountain on top of that will surely not let the nuts bite anymore. For me this is why I am hesitant to buy the mod - it would mean I need to remove the protector plastics.
#9878 8 days ago
BTW I just posted a review with photos of the CPR full mirrored backglass for "High Speed 2: The Getaway". Enjoy the read
https://pinside.com/pinball/forum/topic/review-cpr-backglass-for-high-speed-2-the-getaway
#9879 7 days ago
Yes, I’m betting you would have to replace the two posts with ones that had longer threads.
#9880 7 days ago
Thought I would show off my new addition to the lineup. I arranged them with the taller in the middle for symmetry, but the first thing my son said was that it looked like a traffic light - red, yellow, green. Even how my pins are arranged is an homage to my beloved first Getaway.
I also think it is kind of funny in that I don't have a single manual plunger - probably one of the most iconic things about pinball. I have a gear shift, a gun trigger, and a push button. Oh well, one of these days.
#9881 7 days ago
Congrats on number 3! No 4 is not too far off.
#9882 7 days ago
Quoted from pinballjah:
Well, I think #4 would be a replacement for the wife (not something I want to do), as she pretty much told me point blank that 3 is all we have room for.
#9883 7 days ago
as long as your wife has two buttons to push, a nice backbox and decent shaker, i don't think an upgrade is necessary. lol. sorry - i couldn't resist...
#9884 7 days ago
3 is a good number, I've come to that conclusion for myself only, sure I could probably squeeze 5 into my space but I'm happy with 3. I can swap out one for another if I choose, like I did with my PZ for TS. At this point I'm pretty happy with the pins that I have, maybe would consider changing out my Getaway for a GB, maybe... only thing that could change that is if I find a crazy deal on a project pin, as that is a part I really enjoy, bringing back a beater to it's former glory. Enjoy!
#9885 6 days ago
Quoted from tiltmonster:
That’s what I thought until I got number 4 and now up to 8.
#9886 6 days ago
Looks like there is some room just to the right....
#9887 6 days ago
I know famous last words but deals aren't what they were when I started so getting something that needs some tlc for a good price is getting harder to find. I don't need a NIB because I like working on the machines, that's part of the hobby for me, so I'm ok finding a pin that has been routed but that has nothing to do with the space I've dedicated to my line up.
#9888 6 days ago
Quoted from okgrak:
I wish, but that would completely block the entrance to the door. I might not mind being captive in there, but I could see other issues arising.
#9889 6 days ago
I have a mountain update for all current orders. I just received alert that the plastics have been made and are on their way to me. In the end I chose CPR for both price and reputation. Tracking shows they will arrive on 10/15, so if everything is on time I'll be shipping all current orders mid-next week. I also received all of the lighting today, so that just leaves me with painting the snow peaks and applying a satin clearcoat. I'll get that done by the end of this weekend. FYI, I did purchase a few extra plastics (5 of them), so I'll have a few for any follow-up orders from those of you who may be on the fence or waiting to see what others think before you decide.
#9890 6 days ago
I thought that I’ve asked this before but can’t seem to find it, so I apologize if redundant.
I have an intermittent issue where the left flipper drops at times, but continues to work almost immediately when I repress the flipper button. In other words, I might be cradling the ball and the flipper will just go limp, but I can repress the button and it works (sometimes it takes a few presses). Other times I might press the left button during play and the flipper won’t fire immediately.
Is this most likely just a leaf switch adjustment? Something I’ve been slow to address, but now that I’ve had friends over a couple of times to play, it is kind of embarrassing.
#9891 5 days ago
Need Help !!! I picked up a Getaway and the the game had a fire in upper cabinet
It was swapped out but no beacon, I found the entire assembly but I don’t know size of hole to drill or location
Any help greatly appreciated
#9892 5 days ago
I would clean the contacts of the leaf switch and make sure the is no pitting on the contacts to make sure there is a solid connection. You can use a multimeter set to continuity and test depressing the flipper button to see if it is indeed a leaf switch issue.
#9893 5 days ago
Need help on a repair issue. The display was not working correctly, all the pixels would eventually light, but the images and numbers were sporadic. Then the other day, the display was working correctly, I could go thorough the test menu and see what i was doing, but later in the day, the screen starting losing pixels again. I figured that the display kind of works, must be the display board, so I ordered a rottendog DMD089 board. It finally came in today, i put it in and nothing, machine will not turn on. I double checked wires, connectors, etc. The -125VDC test point on the RD board measured -147 V, which is way more then +/- 5% that i would think would be tolerable. I removed the RD board and put the old one back in and now the machine is fine, well it works, still have sporadic display, but it plays. With the old board, all the voltages are fairly close.
Is there anything special to installing a DMD089 board? Do i need to adjust some trim pots for voltage adjustments? I thought it was slap it in and off you go type of thing. I have no clue on which way to proceed.
#9894 5 days ago
There is a thread about similar symptoms where the gold plated cabinet flipper switch has been replaced by tungsten heavy duty switches. I have something similar on my right hand switches , which I had replaced because they were damaged when I bought the machine. I am about to(when I have finished moving house!) replace the switch with the low voltage switch.
#9895 5 days ago
Sometimes the wood in between the leaf contacts can fall apart causing an issue or as mentioned before, they aren't making proper contact, it's a good starting point...
#9896 5 days ago
Quoted from jtmirolli:
Sometimes display issues are as simple as reconnecting the ribbon cable or replacing the ribbon cable, I have very little experience with RD boards
#9897 5 days ago
Think I might have found the problem on the new RD board. For you technical people, the 100VAC on J605 feeds a bridge rectifier that then runs through a LM337 voltage regulator for the -125 volts, then thru another LM337 for the -115. I'm getting low voltage out of the first regulator so everything down the line is going to be low also. I'm also getting different voltage readings from the test point on the board and the J604 plug, so it is losing voltage somewhere along the line.
Maybe someone has run across this one in the past...
#9898 4 days ago
Quoted from whitey:
I tried to look for you, but I cannot tell what size the hole needs to be as it is covered by the motor assemply. Looks like you'll just need to get the assembly and figure out from that. However, there is a large recess in the top of the backbox that is just large enough for the beacon cover to fit down into. Then a couple of metal tabs are used to secure it in place.
#9899 4 days ago
Took a look, and everything is beautiful (I've done a complete rebuild within the last year or so). However, one of my wire bundles soldered to one of the leaf switch leads was a little loose. A quick re-soldier, and a game to test, and I did not experience the issue. Hopefully then resolved the issue and nothing more serious that randomly rears itself.
#9900 4 days ago
Quoted from Jakusu:
The piece goes over the opto on the ramp
Yo, sorry man can you post a picture ? I have look at all the opto on the Ramp and it does not seem to fit. Its doing my head in
