Quoted from Charger500:I'm slightly off balance but not much. A look at the coil. Not a great solder job. I could reflow that solder. Plunger moves free enough. Looks like I'd need to take the cover off to bump it over to the left a bit.
The good news is your pin level is great the bad news is I'm not sure what'sgoing on with your coil. It's mounted in reverse and I'm not sure what's happening with your tabs and wires. I'd replace the coil, coil sleeve and probably the spring. There is a notch on your coil bracket where the coil should have a tab to secure the coil so it won't move when active.
