Quoted from arolden:Hi guys.
When balls come down from the right freeway orbit, they hit the post sleeve at the bottom of the ball shooter lane gate, usually going to the left slingshot or flipper, instead of returning to the right flipper.
How do I adjust this so the ball returns to the right flipper?
Here is a quick video of the problem; sorry for the poor quality.
Two things solved the same issue for me:
1) Are you absolutely sure that your pin is level from side-to-side? I highly recommend using the PinGuy app on your smartphone. However, you must first calibrate the app on a known level surface (e.g. a hard surface floor or workbench/table that you have leveled manually. Then put the smartphone on the pinball table (not the glass), set to 6.5% and turn on voice, get under the pin and get ready for the lady to bark out how far you are off from front to back & left to right. Make slight adjustments to legs until she tells you that everything is dead on. Again, always calibrate the app on flat surface before leveling your pin. I made the mistake once of doing this after moving my pin, getting under the table and leveling, and then once I was finished realizing the right side was about 2 inches higher than the left. I knew my floor was not that out of level. After calibrating, and leveling again with PinGuy everything was dead on.
2) Make very slight, incremental adjustments to how far the upper flipper sits at rest (about 1-2mm at a time or use something to prop it out and manually roll a ball around the loop until you get the spacing right then lock it in). What will happen is that the ball will run smoothly down the curve and along the rubber of the upper flipper returning it home without catching the post nearly 100% of the time.
