Last night I started getting a Check Fuses F114 & F115 error message. Funny thing is, I got it initially during a game. I don't remember exactly what the game was doing or where the ball was (it might have gone into the Kickback spot or that coil firing might have happened after). But when it happened, I could feel / hear something pop. F115 fuse indeed is blown. The kickback coil fired and the shooter lane coil fired out another ball just after it happened, but the flippers weren't working. I watched this for another few seconds and shut the game off.
When I powered it back on, that's when I got the F114 and F115 error message. And presumably until that's resolved, you can't do anything else with it.
I looked everything over in the backbox and nothing looks obviously burnt or leaking or charred. I pulled out both fuses F114 and F115 and checked them with my multimeter. F114 was okay but F115 was blown. I put a new confirmed good fuse in both spots. F115 is a 3/4 A Fast Blow (even though the manual shows Slow Blow) and F114 is an 8 A fuse. I bought the Getaway fuse kit from Marco a while back. Powering it back up again, this time with the backbox door open and I could see F115 blow immediately right in front of me. F114 is still fine.
So I started searching the forums and find this really great tech write-up: https://www.pinwiki.com/wiki/index.php?title=Williams_WPC#Check_fuses_F114_and_F115_message
One comment in that article mentions a loose mechanical connection of the fuse holder to the PCB. My F115 fuse holder does have a little wiggle to it. I thought, great, that's probably it. I pinched the metal tabs a little closer together and installed another good fuse (3/4 A FB). I also felt around some of the other fuses near it and noticed F116 was a little loose to the touch. Not the fuse holder, but the fuse could be rotated a little. This may have been from an order of fuses I got that were closer to 6.0 mm on the ends instead of 6.3 mm. I put a proper sized one in and it is now snug too. Just trying to be thorough in mentioning, as I'm not sure if that would be related at all?
Ok, so I power it up again and same thing. Fuse F115 blows right away. I did make note of the 7 LEDs on the power driver board. According to the manual, LED's 1,2,4,5,6,7 are all supposed to be lit normally and LED 3 is normally off. My game right now has LED's 4,5,6 lit up, but 1,2,3,7 are all off.
I feel like this means I somehow lost my 12V supply. Does that sound right? I'm not sure where to check next though. Any ideas or suggestions?
The diagram on that article shows how the connections are to J114. It seems like there's got to be a short somewhere to blow that fuse. I can check any components or connections for voltage or continuity, just let me know which ones will help diagnose the issue. Much appreciated!!
IMG_2863 (resized).JPGIMG_2865 (resized).JPGIMG_2870 (resized).JPGIMG_2871 (resized).JPGIMG_2872 (resized).JPGIMG_2873 (resized).JPGIMG_2875 (resized).JPGIMG_2876 (resized).JPG
