I’ve had My Getaway for 10yrs and the beacon just stopped rotating (during game play and in test mode) So I have replaced the Triac board with a new one from Gulf Pinball and replaced the motor and the motor still won’t rotate but the light does come on when it’s supposed to. I know the motor is good, (both old and new motors are good) because I can get them to work if I hook them up to an external bench power supply @ 14vac.
I have also shorted the Q22 driver transistor to ground as a test and that also just turns on the light but not the motor.
One thing I’m not sure on, when I’m checking the ac voltage into the motor, should I have at least 12vac on each wire individually or only when reading across both input wires?
I have 17vac when reading across both white-red input wires to the beacon, But 9.5 vac and 8.5 vac on each wire individually. I’m thinking that’s why the light works because there is enough voltage for the light but not the motor?
