I recently purchased HS2 "The Getaway", the beacon and light don't work. I followed the wiring diagram and found J2 form the Triac board was connected to J105 instead of J104, swapped J104 and J105. The rest of the wring appears to be correct. I'm trying to think of a quick way to test all the way through to the bulb/motor, what points can I hook up a multi-meter or 12v circuit tester to test?
Any and all suggestions welcome.
Rick
