(Topic ID: 80902)
Genie working fine before move
By fna_royam
5 years ago
  • 8 posts
  • 6 Pinsiders participating
  • Latest reply 5 years ago by cro_pinman
#1 5 years ago
I have a Gottlieb Genie that was working at the house with the coin drop at 25 cents ( even at home I like to put quarters in to play. ). I was talking with a local watering hole and I offered to take the genie there. We'll we moved the game there and like an idiot I left a multimeter inside and it banged about a bit before I realized and took it out. Anyway when we set it up the lights go on, the typical 5 second delay and it looked like its ready to play. Problem is it will not accept quarters, which it was doing before the move, but the more serious problem being it won't even allow me to go into the diagnostic mode to switch it to free play. Any ideas about what might be wrong ( and feel free to make fun of me for keeping a multimeter in the cabinet while moving, bonehead for sure)
Any thoughts would be appreciated. I had a tech out to fix some things prior to the move and everything seemed to be running just fine.
#2 5 years ago
For a rough start I'd make sure all connectors are on tight. Pull and check fuses.
No telling what damage may have happened from the loose meter. Or may not have.
LTG : )™
#3 5 years ago
A couple thoughts...
Molex connector from coin door to backbox harness attached?
Coin door ground still in place?
Chris Hibler - CARGPB #31
http://www.Team-EM.com
#4 5 years ago
Quoted from LTG:
LTG : )™
+1
With special attention to J6 (also J1(P1) connector near by tilt assembly )
#5 5 years ago
For a minute I thought this was a Direct TV thread. I was just going to advise you to call DTV and they would send you a new Genie
#6 5 years ago
If you unbolted the head and laid it down, you likely disconnected one or two connectors in the head. Bottom left connector on the CPU is especially short, and goes to the coin door. Once the wires and connector get loose, they can fall through the big hole in the bottom of the head into the lower cabinet, so it looks like nothing is loose when you open the head. With the power off, fish around in that hole to look for loose connectors. I'll bet you'll find one or two loose there. Match them up with the right connector in the head and you should be good to go.
#7 5 years ago
It's fixed - thanks so much. It was the J6 not being connected and it was the J6 that I didn't pull up so it was dangling down. When " it's not plugged in yet" it won't work I guess
Thanks again for the help
#8 5 years ago
Nice, Genie keep on runnin' .
Greetings from Croatia
$ 289.00
€ 8.40
$ 69.95
$ 8.99
Pappy's Pinball Palace
$ 12.50
$ 139.00
Sparky Pinball
$ 48.00
$ 150.00
Various Other Swag
$ 96.95
$ 99.99
$ 89.99
$ 69.99
$ 7,599.00
Classic Game Rooms
$ 229.99
$ 9.99
