(Topic ID: 264695)
Genie Weak Drop Target Coil - Intermmittent Reset
By Genieye
14 days ago
  • 3 posts
  • 3 Pinsiders participating
  • Latest reply 1 day ago by trk12fire
#1 14 days ago
Hello all, crazy times for sure and hope everyone is well. Many of us find ourselves stuck inside and a silver lining is more pinball play so that is why I hope to find a quick solution to this problem.
I posted something similar recently about intermittent Genie drop target reset issues and am posting this new one since there are more things to report and am hoping to get a fresh look at it from the many experts here.
The lower 4 drop target coil is very weak at times, so much so that the targets will either reset very slowly, not at all, or pop up slowly then retreat. They also normally pop up fine when you start a new ball and can be ok for awhile only to repaet the problem. That is the strange part is that when a new ball starts the downed targets pop right up then might play fine then get weak and stop resetting. This can happen at anytime during play, it starts off fine then gets weaker until it happens or can happen on the first ball. Then might be fine for awhile then starts to do the same thing.
The coil reset sounds mushy slow if you can imagine that sound. Also they now will occaisionally reset before all 4 are down which is a new behavior. The upper 7 targets reset fine but do at times reset before they should but a rare occurance.
I have been told to look at the rectifier and maybe replace that? I will have to figure out where that is. It seems like an intermittent power supply issue to that coil. The coil always fires during a NI-Wumpf coil test though can sound mushy. I have a NI-Wumpf CPU and Driver and Rottendog PS. I really hope someone or a few of you can offer insight on this as I hope to get it operating normally for the long strectch stuck at home. Best to all.
#2 1 day ago
Following as well. I have the same exact issue. I have the ni wumph cpu as well.
#3 1 day ago
I don't know to much about Gottlieb drop targets, but I would start by rebuilding them before working on the board. Sometimes the springs will go bad or the contacts need cleaning.
$ 289.00
€ 8.40
$ 69.95
$ 325.00
Gameroom Mods
$ 12.00
Iron Monger Decal Out of stock
Flashinstinct
Top-Notch Target Shields
$ 24.95
The MOD Couple
$ 154.00
Id Rather Play Pinball
€ 279.00
Displays
PINBALLSP
Various Novelties
GC Pinball
$ 29.95
$ 5,899.00
Classic Game Rooms
$ 5.00
Metal-Mods
$ 7,599.00
Pinball Pro
$ 299.99
