(Topic ID: 259104)
*Genie* Phantom Slam Tilts - Help!
By mrgregb123
47 days ago
  • 5 posts
  • 4 Pinsiders participating
  • Latest reply 46 days ago by pinmike
#1 47 days ago
I've owned this game for a year now and every 10 or so games, it seems to randomly slam tilt. There is no rhyme or reason. Sometimes it occurs 2 minutes after the game was turned on, other times after 30 minutes. Sometimes never.
As far as I know, there are two slam tilt switches in the game. The one under the center of the playfield is open by default and the contact switches are very far apart. It would impossible to activate this if you threw the game across the room.
The other slam tilt is the one to the left of the coin area that relies on a rolling ball to break a closed switch. This one I've used a leaf adjuster to push closed as tightly as possible. It doesn't move at all and the contact is pretty good. I would ideally like to short this closed permanently but I'm not entirely sure which of the 3 wires to solder together. At least then I can be absolutely sure it's not this switch. And then if that's the case, anything to check elsewhere? Thanks for the help!
#2 47 days ago
There is also a slam switch on the coin door near the lock.
If you want to permanently disable the slam tilt feature - a common fix for this rather glitchy design - put a jumper wire across the legs of capacitor C2 on the CPU board, as seen in this photo:
https://www.flippers.com/images/Got-Sys1-SLAM-Defeat.JPG
This is one of several things I am working on in the process of getting my Totem back into full functionality.
#3 47 days ago
What mpu does it have? Original?
#4 47 days ago
Ni-Wumpf, so I can't do what gornkleschnitzer suggested. No option to disable in the settings either.
#5 46 days ago
Same exact problem we are having here and new boards also Ni-Wumpf.
https://pinside.com/pinball/forum/topic/genie-system-1-will-not-boot/page/4#post-5395680
Senoia, GA
€ 8.40
$ 69.95
$ 289.00
$ 6.00
German-Pinball-Modular
$ 40.00
Arcade Arts
Game Room Info Shop
Apparel - Unisex
Project Pinball Charity
$ 22.00
Hardware
The MOD Couple
$ 16.00
Pin Monk
Cabinet Parts
Maple Street Sign Shop
PCB Emporium
$ 9.99
$ 9.99
Bent Mods
$ 369.00
$ 175.00
Professor Pinball
$ 4.49
$ 218.00
