Quoted from phishrace:The incoming voltages on a System 1 power supply board are all AC voltages. Voltages are tested at connector J1 on power supply board. Bridge power goes elsewhere. Highly unlikely your AC voltages are missing. Testing a System 1 power supply isn't simple. Follow the instructions in the link below.
http://www.pinrepair.com/sys1/index.htm#power
I agree with you 100%
Last week I was on Clays page. On the bottom panel I checked all of the fuses for continuity by removing them. There were 6 plus the two by the power supplies. One was bad so I replaced it then they all checked out. I checked only one playfield fuse that I could find.
Then I put my DMM on diode and checked the bridge rectifiers they all were either .4 or .6 so they were ok too. From there I went to the original system 1 power supply. At that point i had the correct voltages at a2/J1 on the connector from the bottom panel they were:
pin 1 = 11.4 volts AC
pin 2 = 11.4 volts AC
pin 3 = common
pin 4 = 13.1 volts AC
pin 5 = 13.3 volts AC
pin 6 = 68 volts AC
pin 7 = 68 volts AC
At this point i had no computer controlled lighting. I had general illumination. If I left one of the connectors unplugged the displays fully lit but did not show anything.
Now the Bridge rectifiers are showing zero. The fuses all still have continuity. All of the pins above show zero. The thoughts that I have
Is the ball tilt open when it should be closed. I see two slam switches do they look like they are closed when they are actually open?
Did I short something when removing and installing the connectors. Did the bridge rectifiers get shorted out or die?
