(Topic ID: 215180)
Genie backglass restore/freshening up
By Jaymach1
1 year ago
  • 22 posts
  • 4 Pinsiders participating
  • Latest reply 1 year ago by Gunnut40
There have been 19 images uploaded to this topic. (View topic image gallery).
#1 1 year ago
Hey guys, just finished a restore/major touch up on my Genie backglass. Imo Genie has one of the best back glasses ever but this one was hurting. Like most, the reds were mostly gone or ready to flake off and the skin tones were starting to flake.
#2 1 year ago
Let me start by saying that there may be better ways to do this but this was the most budget friendly experiment. My thoughts were to try to airbrush the worst parts with a translucent paint. As you can see it was pretty bad. I decided to completely remove all of the red from "GENIE" as a test to see if this would work.
#3 1 year ago
I painted "GENIE" first and was really happy with the outcome, even when back lit.
#4 1 year ago
FYI, I am using createx translucent airbrush paints. I did have to use a couple non translucent paints which I reduced.
#5 1 year ago
Lots of tedious scraping with a small razor and pick
#6 1 year ago
Here's what the back looked like after some of the red work and skin tone work.
#7 1 year ago
For the skin tone I started with createx transparent peach. It was pretty damn close. Didn't take much mixing to get the color right.
#8 1 year ago
Any paint that was loose or flaking got scraped off.
#9 1 year ago
I went back over the colors with a light reduced spray of white, that way when back lit the repaired areas weren't jumping out at me.
#10 1 year ago
More progress
#11 1 year ago
2 of my score display windows were pretty bad. I decided to scrape the turquoise silk screening off after a failed attempt at using reduced translucent turquoise paint. The transparent paint, even though it was greatly reduced was more cloudy than clear. So for now the windows are clear. I did order transparent turquoise vinyl so I'll update you guys when it comes to let you know how it looks. amazon.com link »
#12 1 year ago
With the airbrush work done, I heat set the paint, then taped off the score display windows and shot the bg with triple thick. Any mistakes with createx paint are easy to erase until it's heat set.
#13 1 year ago
Really happy with the outcome pre back lit.
#14 1 year ago
Back lit looks really good too. Much better in person. The picture doesnt do it justice. Thinking about color changing leds for the genie smoke. I consider it a victory, the game is back to the glory days of old. Hope this helps someone out. A little before and after back lit
#15 1 year ago
How much time do you have invested start to finish? Looks good.
-Mike
#16 1 year ago
Quoted from Grizlyrig:
-Mike
Thanks Mike, probably a solid 12-14 hrs. Scraping the paint off took more time than anything. Better than buying a new one though and way cheaper
#17 1 year ago
Wow, that looks wonderful. Do you think you could do the same thing with my Genie backglass? Most of it looks fine, but the bright red on the wizard and the word "Genie" has cracked and and separated forming a pattern of lines instead of a solid red like is should be.
#18 1 year ago
Hmmm...did you use triple thick before? I'm going to do a back glass at some point.
#19 1 year ago
Quoted from kst8cat:
Ya the red seems to be the issue on these backglasses. The red on my game was turning to dust. Since yours is just the red it would be a good candidate. Scrape off as much red as possible, then transparent red mixed with a little orange
#20 1 year ago
Quoted from Gunnut40:
I didn't triple thick before because I was removing large areas of the red flaking paint. If the bg was flaking everywhere I think TT would be a good idea before you start. I did TT after I heat set the repairs. If you are just wanting to fix the reds this was a complete success. The red looks incredible. The skin tones were tougher to get right but I'm very happy with the before and after.
#21 1 year ago
Also, this is probably obvious, but never tape off areas of the backglass. You will have even more areas to repair after you remove the tape. I may have done this once. Dohhh
#22 1 year ago
Quoted from Jaymach1:
Ok thanks!
1,600 (OBO)
Cincinnati, OH
€ 8.40
1,800 (OBO)
Bristol, VA
$ 289.00
$ 69.95
Hagerstown, MD
$ 5,799.00
Classic Game Rooms
$ 104.00
nvram.weebly.com
€ 4.20
Buthamburg
$ 154.00
Id Rather Play Pinball
$ 7,499.00
Classic Game Rooms
$ 10.95
$ 289.00
$ 16.50
$ 4.49
Yorktown Parts and Equip
$ 495.00
MI Pinball Refinery
