(Topic ID: 248411)
Genesis system 80b display blank and sound gone after a while
By zezami
  • 6 posts
  • 4 Pinsiders participating
  • Latest reply 3 years ago by zezami
#1 3 years ago
I have recently bought a gottlieb Genesis that I've restored but after a few minutes of playing the display and sound dissapears, the game continues to function though so it's not a complete halt of the mpu. If I turn the machine off and on again the display and sound is back for a about the same time before it dissapears again. Anyone have an idea what might be causing this? I initially had trouble with the mpu not booting at all and it turned out to be a failed RIOT for the display which I replaced.
#2 3 years ago
I would start with mandatory ground mods in the cabinet and head first. Done several 80B at this point and it is amazing how many problems ground mods solve. Display is a little troubling as not part of ground mods, check to make sure contacts on lower right MPU are clean.
#3 3 years ago
The EXACT same symptoms......took a guy [I don't do boardwork] about a minute to figure out the issue. Not home right now,so I cant take a pic, but the 4 wire connector right at the top centre of the backbox needed repinned bad. He plugged it back in and game worked
perfectly......
#4 3 years ago
Ground mod is done already, 5v capacitor and potentiometer replaced.
Haven't done any repinning yet so that might very well be the case..
#5 3 years ago
Did you verify you are actually getting 5v to the boards? I had a display not turn on from having a poor connection at the power supply as well, like the user above.
3 weeks later
#6 3 years ago
So I finally managed to solve this issue. I noticed that the display and music went out when a coil fired. I didnt notice at first what coil it was but it turned out to be the left slingshot only, no other coils caused the display and sound to dissappear. Turns out the diode on the coil was loose in one end. i measured the diode and got an ok reading from it and resoldered it and the problem is now gone!
$ 83.00
PinballReplacementParts
Gweem's Mods
Sound/Speakers
$ 5.95
The Pinball Scientist
Protection
Men
$ 334.95
Allteksystems
Other
This page was printed from https://pinside.com/pinball/forum/topic/genesis-system-80b-display-blank-and-sound-gone-after-a-while and we tried optimising it for printing. Some page elements may have been deliberately hidden.
