Genesis is driving me nuts. I had Genesis working. Cleaned it all up, and played a few games. In the middle of a game, it just ended the game. Everything works like it should as far as attract mode and lights. None of my switches work, including the test switch.
I did the ground updates, which fixed my sound issues, but not the switch issue. Here is I have checked/done so far:
Checked all the fuses = good.
Good 5 VDC on all the boards.
Fuses F 9-F 12 have no power to them. F 13-F 15 have power. If I jump from F 13 to F 12, I can play a game as far as all the solenoids including the flippers work. The game stays in attract mode.
I have bypassed the test switch, and coin switches, but no luck.
Cleaned all edge connectors, no change.
Swapped U 4 and U 5 on the Main board (Switch matrix and Display chips ((same)), no change. The display still worked, but none of the switches.
Any help would be appreciated. Thanks,
The Post Master
