(Topic ID: 287504)
General resistor question
By Seamlesswall
8 months ago
  • 3 posts
  • 3 Pinsiders participating
  • Latest reply 8 months ago by wayout440
    #1 8 months ago
    Ordered 1/2 watt metal film resistors from Mouser and I assumed you could kind of tell the wattage based on the size of the resistor. Not in this case! These things are tiny. So the question is: is this simply because of modern manufacturing practices? Label clearly marked and checks with meter. If I ever lost the label I wouldn't know the wattage capability?. In Mousers case, they use heat labels and given a few years they fade...
    #2 8 months ago
    You might have ordered small form factor resistors. This would be a 1/2 watt resistor at about the size of a 1/4 W resistor.
    #3 8 months ago
    Are they this tiny? I've had these blow off to neverland a few times. Unless you are in a clean room with a solid color floor you'll often never find them again.
