(Topic ID: 195390)
GB LE - Replacing a LED Bulb Question
By gjm7777
2 years ago
  • 13 posts
  • 7 Pinsiders participating
  • Latest reply 2 years ago by chuckwurt
#1 2 years ago
Hey all,
So I'm looking to change out a few LEDs from the bright whites at the areas below. Does anyone know from experience if these bulbs/sockets can be dropped from underneath the playfield or would I have to remove the top plastics to get at them?
Thanks in advance
#2 2 years ago
These days you should always be able to get to them from the bottom.
#3 2 years ago
Also a side note when I changed out some bulbs to the optimax from comet i had what appeared to be node board issues. I put in regular non ghosting bulbs from comet and the problem went away. The area I had issues with were bulbs 117 and 121 the lower bulb on the slings.
#4 2 years ago
Thanks for the details guys. I ended up getting the Ablaze 1-LED #44/#47 Bayonet Base Lamp With Flat Top Lens.
Hoping these don't cause issues.
#5 2 years ago
Welcome to the wonderful world of spike where the simple act of changing a bulb is no longer simple. You cannot put any bulb in there. I would contact stern tech support and ask them what to use.
#6 2 years ago
Are the LEDs not soldered onto the board itself? Thought it was...
#7 2 years ago
Quoted from FatPanda:
Gi bulbs are still in sockets as are flashers. Inserts are on boards and cannot be replaced.
#8 2 years ago
Quoted from Lermods:
That makes sense. Thanks!
#9 2 years ago
Well,
It looks like the Ablaze 1-LED #44/#47 Bayonet Base Lamp With Flat Top Lens do not work at all. Not lighting up when powering up the game.
*Edit looking at the original bulb it was 6.3v AC but the replacements are 6.3v DC - Perhaps that is the issue then.
#10 2 years ago
This is good advice. With SPIKE you can cause damage or problem with the node boards, especially if you try to install an incandescent.
I would make changes with caution. The SPIKE system does not have fuses, if you create an issue the board may shut down.
#11 2 years ago
Thanks for the advice,
I do see these are listed as AC/DC
http://www.cometpinball.com/product-p/8mm-led.htm
But I've reached out to stern , and I'll see what they say for a replacement. I figured there had to be a few people who have replaced these by now.
#12 2 years ago
Stern got back to me right away, and their response is the bulbs simply need to match the existing spec.
I'll report back after giving the Comets a try (which are marked 6.3v AC/DC)
#13 2 years ago
Quoted from gjm7777:
Should be good if you use the twin 2835 2 smd bulbs. Those are the exact ones stern uses.
$ 12.00
Meph's Mods
Shawnee, KS
$ 69.99
Mc Cutchenvle, OH
Olive Branch, MS
$ 149.99
