Here's the trade secret to shortening a spring.
Figure out where you want the length to be. Maybe mark with a sharpie if you want to. Now, put it on the 90 degree angle of the top of a metal vice at a 45 degree angle to the top (you could use something else but it needs to be hard. Timber would be no good)
Now ... smack it with a hammer! The spring now looks like it is at 90 degrees at the mark. Now, grab wire cutters and trim the excess off to suit.
I was taught that trick by a diesel mechanic when I was a kid. Works every time.
With the PBL springs, the ones fitted to the Pro I have on loan at my house (thanks Chris!) were bending the plastic targets and making the drops fall and they would machine gun. That's pretty hopeless to be honest. The targets are so flexible, they bend and fall off the locking ledge. To fix it, I reversed the bottom washer to the inside, which created more angle and the target now locks 100% on the ledge. Easy fix.
Personally, I would have just shortened the stock springs a little. Takes 2 minutes and costs $0.
rd
