(Topic ID: 225462)
Loft gameroom build DONE!
By MT45
2 years ago
  • 366 posts
  • 86 Pinsiders participating
  • Latest reply 1 year ago by PAPPYBALL
  • Topic is favorited by 75 Pinsiders
    There are 366 posts in this topic. You are on page 1 of 8.
    #1 2 years ago
    Thought I would use the thread where I was asking for advice to give you all updates on the "Pinball Loft Arcade" build!
    If interested, stay tuned here for updates and links to my blog on the progress we are making.
    Below are questions I was asking a few months ago - but now we are well underway on the build so skip the first post and find out what's been done!
    Lots of work but going to be worth it
    After spending almost 2 years in a temporary house that was already sitting on our ranch property, we are finally beginning our build of the new house
    It will not have a basement for various reasons so I was left to decide to spend significantly more to add my 1,500 sq/ft gameroom as a grade level part of the house OR ... Simply build it above the (large) garage that will already be there.
    So, above the garage it is.
    Attached is layout and drawings of the space:
    - 48 feet wide by about 31 feet deep
    - Drawing shows 40 games now - spaced about 6" to 8" apart - could probably squeeze as many as 45 games in there in a pinch
    - (I know they look close together but each PB sample is drawn at a 36" x 60" scale so the examples are larger that a real PB)
    - I will build a small workshop/parts closet in the corner
    - No restroom (dowstairs right at bottom of stairs if needed)
    - Dormer will be 48" wide and will go out to the back of the house onto a shallow deck
    - One thought is to use one corner of that deck with a DIY lift (winch/unistrut/platform)
    - Another thought is to use a version of JoeGrenuk and his "pinball escalator" (tow it up the stairs!)
    See Joes awesome work here
    https://pinside.com/pinball/forum/topic/how-many-pins-upstairs#post-1862961
    My plans so far:
    - Ambient, color changing lighting that will be indirect (I have a complete HUE set) in nature - dedicated switch
    - Bright work lighting that will be very direct (to work on games)- dedicated switch
    - 9 dedicated 20 amp runs so I can run 5 games per circuit
    - Individual "Etekcity" type electrical remotes so each game can be remotely and independently controlled
    - Physical disconnect box so I can pull that lever and completely decouple the games from the electrical grid in the home (lighting)
    To make certain "the floor will hold the weight" my builder will employ a structural engineer
    I'm using this math:
    - 45 pinballs and 20 people above garage
    - 45 x 250lbs each = 11,250lbs
    - 20 people x 175 lbs = 3,500lbs
    - Pinballs will be distributed (see image) about 1/3, 1/3, 1/3rd in the room with 2/3rds of them along supporting exterior walls
    In prep for all this, I have a series of questions:
    1. How do you get games up there? Alone?
    2. Any conveniences that are a "must have" in your gameroom?
    3. Fooring preference when your upstairs? Does it matter?
    4. Lighting recommendations? Placement, type, etc.
    5. How do you deal with the windows with games in front of them? Blackout? Leave as is?
    6. Paint color schemes (oh boy ... can of worms here!) Light (why?) Dark (why?) Other ...
    7. Electric remote controls you are in love with (Etekcity seems to work well but I'm open to others)
    8. Anyone using a physical electrical disconnect? (needs to disconnect and create a minimum 2" gap between contacts)
    And, of course, I welcome any and all thoughts/opinions/warnings/considerations
    Thx guys
    GR_loftV3 (resized).JPGIMG_2429 (resized).JPGIMG_2430 (resized).JPGIMG_2431 (resized).JPG
    #2 2 years ago
    Quoted from MT45:
    Don't. Get help. Live longer.
    #3 2 years ago
    175lb per person? These are pinball people?
    You'd better up that mass estimate...
    Later,
    EV
    PS....for getting pins in and out, get yourself an Escalera
    7 months later
    #4 2 years ago
    We started here ... cutting the hilltop on our 40+ acre ranch to pour footers on our new home
    I got inspiration from you all on Pinside and from rotordave who was kind enough to offer advice and blueprints of his designs
    These are some of the images from "Show us your gameroom" thread that inspired me
    #5 2 years ago
    We are here now after 5 months. Started in October of 2018
    #6 2 years ago
    Now onto the juicy stuff ... the Pinball Loft Gameroom!
    Here we see the crane lifting the (over 40 feet long) trusses that are engineered to hold the weight of 50 pinball machines +25 people
    The laminated beams they rest on are enormous and had to be lifted by crane also
    Here's a Youtube video of one of the trusses being set. The engineering to put that many games on a second story over a 5 bay garage required MANY more of them than normal and spacing closer as well
    #7 2 years ago
    Now fast forward a bit to framing is completed, roof deck is on, roofing is done and it's my turn to step in
    I did all of the wiring in the room except for setting the panel.
    I wrote the electrical diagram on a 3x5 card, then created a more accurate one in Excel
    When you run LEDs almost 200 feet, everything changes ... I have ordered test parts and amplifiers to get ready to the final install
    I'll report back on this later - I added 6 dedicated outlets at ceiling height to accomodate this
    #8 2 years ago
    Finally! A picture of the room. It's at night because that's the time I was mostly over there after work laying in over 1,000 feet of 12/2, 14/2 and 14/3 wiring
    Some of these images show outlet placement and dressing. Note the dedicated dual 4 gang switch boxes (all the yellow wires!). These switches run to 8 total dedicated 20 amp circuits with each handling around 6 or 7 machines in total. I can turn the "room on" in banks of 6/7 machines at a time or flip all 8 switches at once to light the whole room up. Running dedicated circuits adds tons of time and much more wire of course because EACH circuit is a "home run" back to the panel and each circuit "only" handles about 3 outlets.
    IMG_3982 (resized).JPGIMG_4011 (resized).JPGIMG_4012 (resized).JPGIMG_4045 (resized).JPG
    #9 2 years ago
    Room is prepped to receive sheetrock. Floor covered in tar paper and all insulation is in
    They insulated the entire house in ONE day!
    Sheetrock arrived last week and in a day and a half (max) the entire 1,900+ sq/ft was done!
    The area above the garage is about 48 x 40 deep or so, this includes two small storage areas at the back at about 6' wide by 20' long
    So ... the Pinball portion is about 45 x 34 or around 1,500 sq/ft
    IMG_4431 (resized).JPGIMG_4434 (resized).JPGIMG_4435 (resized).JPGIMG_4436 (resized).JPGIMG_4855-1024x768 (resized).jpg
    Short video of them stuffing the sheetrock into the house!
    13
    #10 2 years ago
    Sheetrock is all up and waiting to be finished. In the meantime, here are some more design details:
    I've had to start planning my title layouts - widebody vs standard and head heights, etc.
    Plus ... decide what games should be "featured" as you enter the room
    So ... about a month ago, I was searching for "life size action figures" and stumbled on Spidey here
    He is just shy of 8 feet tall and will be one of the first things you see when you enter the room - right next to the SMVE!
    Also found a nice condition Rock-ola 488 and filled it with hits from 70s and 80s - that goes in the corner
    Title layouts (resized).JPGIMG_0059 (resized).JPEGIMG_4229 (resized).JPGIMG_4177 (resized).JPG
    #11 2 years ago
    Wow that looks great!
    Congratz MT45
    #12 2 years ago
    Some more loft design details to share:
    First, the height of the lower part of the garage is 9' + so ... that and the fact that the Pinball room is also 9' high and combined this drove the overall stairwell ceiling deck height waaaay up there. It was so high up we wondered how we would change light bulbs.
    Then it dawned on us. Why not cut that ceiling height down, add a sleeping loft - like built in bunk beds?
    Folks can climb up there and sip a glass of wine and chat while others play PB or we can use it as a spare bunk when the house is full!
    So that's what we did - it's interesting that I named the Pinball room the "Loft" before the idea was even hatched - funny how things work out
    Here's an image of the inspiration. Of course, it wont have the bottom bunk, just the upper
    I built in switches in the upper to shut off lights once you're up there
    I added outlets to charge your phone/tablets
    I added 3 total mini can lights and will probably run some HUE RGBW bulbs in there
    Now the picture of how it looks all sheetrocked in. If you bunk in there, you'll find just enough room to sleep toe to toe (it's 11+ feet long) as long as you're not super tall. The bunk area is about 45" deep so you "could sleep" side by side but will need to know each other really well
    #13 2 years ago
    Electrical details:
    First we have the switch boxes for the 8 dedicated 20 amp circuits that will power the machines
    Now the main supply panel ... 200 amps to run all the machines, lighting, fans, a fridge and the dedicated/zoned HVAC system to keep everyone cool
    Main "light switch" box as you enter - gives control to everything at entry
    #14 2 years ago
    Finishes. Probably the hardest thing for any of us to choose, right?
    Originally, the PB room was supposed to be left "out of scope" and out of the budget. I would finish it alone and later
    That did not happen.
    Thank goodness
    So as we slowly came to the conclusion that it WOULD get completed as the house was done, we needed to shift our thinking
    I was originally going to use the raw Advantech OSB flooring and just paint it - but with Pinballs and such, I abandoned that approach
    The reason was that I began to find very affordable flooring
    Sams Club specifically has 14MM laminate flooring WITH foam backer "pre-installed" on each piece for about $1.79 Sq/Ft.
    So I picked a color (Driftwood) and picked it up - the picture is just one pallet because each weighs about 2,000lbs.
    I needed exactly 2 pallets or 132 boxes - too much weight and too big for one load!
    Now onto a complimentary paint color and boom - Natural Linen is a nice neutral match AND ... as you know, you won't see much of it in the room to due to the heights of the games
    #15 2 years ago
    Pics of completed sheetrock install. Still needs mud and finishing work but all the sheets are up!
    #16 2 years ago
    Supplies for the LED perimeter lighting.
    This will be around 200' of 10MM 5050 LED lights at 4 watts per foot power consumption
    To reduce voltage drop and make certain the brightness is even, I'll need to run parallel runs of 32 feet each AND, importantly, I'm using 24 volt stuff. More expensive than 12 volt but necessary.
    The LED strip will be mounted about 5" down from the ceiling and in many cases will be the sole light supply while in the room playing games. I've installed a smaller version of this at my previous home and that is how we used the room 90% of the time. As you can see from my previous posts, I've got plenty of regular lighting when it's needed for working on games, etc. (over 20 can lights in the ceiling)
    I'll be using 2 of these silver "Meanwell 600 watt" power supplies, 4 of the RF receivers and about a dozen reels of the 24 volt LED strips.
    Each PS will drive a little under a hundred feet of LED lights or about 375 watts - well within the tolerances of the PS
    All of the RF receivers will be linked and will receive signals from a wall mounted RF transmitter (not pictured)
    Thinking of using MDF as my wall mounted molding to hold it all - we'll see.
    Plan would be to rip 4" sections from an 8' sheet and use my router to create a 10MM mounting channel. If I go this route, there would be no need to first add a nailer strip like you do when you install crown for this application. Plus the squared off look of the MDF is more appropriate to the room as I do not have/want crown molding anywhere in the house
    Details and testing to follow ...
    #17 2 years ago
    Quoted from MT45:
    Room looks great! I would use room darkening shades on the windows. Eventually, you are probably going to put pins there too, looks that that is your pin "expansion" space (36 is not enough!), drapes may get in the way.
    For paint, I like the dark look, but will it be too dark with LED perimeter lighting? What was the color in your last space?
    #18 2 years ago
    Quoted from ReadyPO:
    Great comments all around:
    1) Yes, I plan on adding the UV inhibiting (nearly 100% reduction) film to all windows
    2) You guessed it, the windows ARE my expansion space (and the main floor has room for 6+ more)
    3) Last space was also a very light wall tone, with white ceiling. Worked out great there. The floor was medium/dark Acacia hardwoood
    All comments and suggestions are appreciated!
    Now is the time to get this right
    #19 2 years ago
    Now would be a good time to install a whole house surge suppressor in the breaker box!
    #20 2 years ago
    Quoted from mbwalker:
    Now would be a good time to install a whole house surge suppressor in the breaker box![quoted image]
    Great idea. I'll get with my electrician as they start to make the panel up
    #21 2 years ago
    Quoted from MT45:
    Forgot to add and FYI in case the electrician doesn't realize it...ideally the suppressor is located at the first 'breaker' spot in the box - closest to the main feed. It needs to be between the feed and all the other breakers. And the grounding wire should be short as possible in order to reduce inductance.
    BTW, excellent build and documentation!
    #22 2 years ago
    Happy Easter everyone! Because it's Easter, I did not get too much done on the build today BUT accomplished at least one critical thing
    I had been searching for the perfect barnboards to install on the face of the sleeping loft in the Pinball room
    The Home Depot "barnboards in a box" was nice but felt like it might look like a million other homes when done
    I really needed 1/2" stock as well because that it how I set the relief on my electrical boxes when I installed them
    Then it hit me that cedar fence pickets were 1/2" and cheap and pretty good looking too.
    So I checked to see if Home Depot had any that were not pressure treated - boom - they did!
    for about $1 per square foot they have #1 grade Incense Cedar fence pickets. They are 6 feet long and to use them for wall decor, you just need to trim the dog ears off to make the ends square.
    Only problem? NOT kiln dried. In fact, opposite - super, soaking, dripping with water - wet!
    So I dropped them in a pile in the pole barn until (today) I could get to them to stack for air drying
    Got 'em loaded in the 4 wheeler and off to the barn shed area that we use for hay storage for the horses - I'm temporarily hijacking the back part
    Stacked them up with some 2x4 on end between and added a fan
    IMG_4485 (resized).JPGIMG_4487 (resized).JPGIMG_4488 (resized).JPGIMG_4490 (resized).JPG
    Look at some of the grain and colors in this wood - it's going to be awesome!
    Skip saw marks in the wood - rough marks, knots and all!
    #23 2 years ago
    Quoted from MT45:
    Are you going to stain, weather or leave natural?
    #24 2 years ago
    Great question ... actually looking for suggestions. I'm inclined to stain but only lightly and then seal with a mat finish sealer
    See previous posts for floor coloring - any help appreciated
    #25 2 years ago
    You could age it with steel wool and vinegar - would look pretty good next to your floor, I think. take steel wool and put in a jar, add white vinegar, and let set for a couple of days. Paint it on - more coats for darker. Lots of Youtube videos on it and faux distressed wood treatments. You can mat finish over it if you want a slight sheen.
    Or if you want a little more contrast, try a premade gray stain, the gray would pick up the wood tones in your floor, and goes great with linen paint.
    #26 2 years ago
    Very cool build. Curious what you are going to do about getting games up there.
    #27 2 years ago
    Very cool space, well done!
    #28 2 years ago
    Great space- lots of room for tons of pins - where did you get the spidy on the light post?
    #30 2 years ago
    A mix up of colors might be nice too.
    #31 2 years ago
    Thanks for all that and the images help a ton. Lots to consider there and a variety of options. The gray does help connect to the floor
    Quoted from kcZ:
    Escalera. I also have a 12' x 10' deck out the back so "if" I needed to add a lift I could add it later
    Quoted from zpinman370:
    Spidey is made by Rubies out of NYC. They were a Marvel licensed limited issue item and hard to find "at a reasonable" price. I've seen them at $5,000 and up but I got this one for much less. That single purchase led to the purchase of my SMVE ... such a disease
    Keep the thoughts and feedback coming - all is helpful as we finalize the space
    #32 2 years ago
    LOL...holy crap...congrats...looks EPIC!
    #33 2 years ago
    Amazing!
    #34 2 years ago
    First coat of mud on in the Pinball Loft today.
    In addition to mudding the Loft, the sheetrock guys also did the following and in only 6 hours AND with just 3 guys:
    - They hung the entire ceiling and most of the walls of the 1,900 sq/ft garage below the Pinball loft
    - They hung the ceilings of most of the main house (3,500 sq/ft)
    Holy moly
    #35 2 years ago
    Quoted from MT45:
    Holy moly
    Looks awesome! Yeah, those guys are animals! I’m always amazed how fast they can get shit done and I see it everyday! Can’t wait to see the next phase.
    #36 2 years ago
    Quoted from MT45:
    Holy moly
    We experienced the same thing with 100+ sheets of drywall. Drywall guys showed up around 8:00AM. The wife called said two guys are here. I remember saying "Two guys per room?" Nope, two...period. Fast forward to about 3:30PM - 6 rooms/areas and ceiling done. Couldn't believe it until I saw it. But yup, done. And done well. Another partial day for sanding, etc., and one more partial day for the Spanish lace on the ceiling.
    Simply incredible, and very reasonably priced.
    #37 2 years ago
    Looking great. Following along....
    #38 2 years ago
    Second coat of mud is on and all the sheetrock in the house is hung as well.
    Chris asked me to take a picture of the storage area behind the pinball room. I saw him peaking in there and lingering for a second.
    When I took a look, I knew immediately why ... the HVAC unit looks like Iron Man hanging out in there
    #39 2 years ago
    You have got one kick azz start to a game room.
    Here’s a few pictures of the lift/elevator I built to get my games up to my loft game room.
    I’m a fabricator, so I built it in less then a day. Nothing to hard if you or a friend have a welder and can do simple framing. You’d have to cut a hole in the floor of the game room floor somewhere and mount the winch in the attic in the game room.
    Lots of ways to do this style setup but this is just how I did it. It’s very easy to move pins and slots up and down now.
    (I’ll put info with each picture explaining what your seeing, and where it’s at.)
    #40 2 years ago
    Lift platform on ground floor
    #41 2 years ago
    Lift platform at second floor height.
    I just have a hole cut in the sidewall of the second floor to slide the games into the lift.
    You can see the cables coming to all four corners of the platform. The cables feed up through the ceiling into the attic where the winch and cables and pullys are mounted.
    16A28C16-5F44-4377-8BDA-41ECB7949AB8 (resized).jpegC0BE4676-2849-498E-94EA-47B5A6433170 (resized).jpeg
    #42 2 years ago
    From inside loft game room, sliding Deadpool off the lift and into the loft game room.
    #43 2 years ago
    Here’s the winch and cables in the attic.
    Just one winch
    (harbor freight $165 https://m.harborfreight.com/1300-lbs-electric-hoist-with-remote-control-62853.html )
    8 pullys and four cables wrapping around the drum of the winch.
    Lifts pins easy, sure beats the heck out of caring them up stairs
    #44 2 years ago
    Quoted from jeep-mustang:
    Just one winch
    Awesome job! Thanks for all the pictures. That looks like what I had in mind and if I build it, I've now got a head start
    Thanks again and congrats on finding an effective way to get your games upstairs!
    #45 2 years ago
    Thanks for the pictures, looks really slick.
    #46 2 years ago
    Great looking area, will be awesome when finished.
    #47 2 years ago
    Testing wood moisture levels in the pile today. Looking to get the cedar boards to around 8% or so before I move them into the space once the HVAC is up and running. Trying to get as little shrinkage or swelling as possible. I'll be painting the sheetrock dark brown behind the planks to hide any gaps as well.
    Out of 18 boards I tested in total, all were under 10% already except for 2 which were in the 15 range.
    For any that remain high when I need them, I'll just set aside as I bought quite a bit extra
    #48 2 years ago
    Bought some artwork for the room to go with Iron Man and Spider-Man. Like I need more art
    I've got a storage area full of it ready to hang and some new Wonka pieces at the framers - oh well, at least I can pick and choose what to put up
    These were very inexpensive and you can still get them at Hobby Lobby. They are lenticular and very well done
    In the "pause time" as I wait for sheetrock to finish, I've been crazy busy on the ranch too
    Today, Chris and I put up another 200 feet of 3 bands of electrobraid fencing to cut one of our 3 acre paddocks down to a smaller 1/2 acre area
    We have a horse that is in rehab and needs to be contained and kept closer to the barn
    This is a temporary setup so I sleeved the 4x4 posts that support the electrobraid.
    When we are done, we can unhook the pins on the terminated ends, slide those 4x4 posts our of the sleeves and insert a "dummy post" that is just the depth of the buried part with a cap on top and put all the parts in the pole barn to deploy later if needed
    We got the holes dug, sleeves cemented in, the endclamps on, the 4x4 stringer post fence guides on and electrical connection made in just 2 hours
    I just tested it and we are getting north of 7,000 volts - should keep the horses off it
    Lastly Tami and I took a well deserved break just before dinner and walked back along the trail past my shooting range
    What a beautiful night at around 75 degrees with a little breeze.
    The sun was just beginning to set - what perfect weather
    #50 2 years ago
    Quoted from MustangPaul:
    You have a good life.
    Amen and no complaints. The ranch work never ends but it’s outdoors and I love it
