Game boots up fine and worked earlier today. I shut it off to change some bulbs and now it won't start.
It shows credits. Aftermarket MPU is set to freeplay. Start switch has continuity across leafs when pressed and all the way to MPU connector. Connector is seated. I looked at the tilt switches and they are not closed. It launches a ball into the shooter lane when you fire up the game but doesn't start the game. When I put the ball back in the trough it automatically cycles them to the right.
I don't see a stuck switch anywhere.
I tried going thru the tests and hit reset on the MPU.
I am out of ideas.
