(Topic ID: 225061)
Game Plan Super Nova Board Question
By Playdium
8 months ago
  • 6 posts
  • 5 Pinsiders participating
  • Latest reply 8 months ago by schudel5
#1 8 months ago
Is there anything that looks like a potential issue with the boards pictured? I'm an EM guy and would have to have a tech go through this.
Many thanks
IMG_2178 (resized).jpgIMG_2179 (resized).jpgIMG_2181 (resized).jpgIMG_2183 (resized).jpg
#2 8 months ago
On the last picture, second fuse from the left looks suspicious.
#3 8 months ago
Quoted from Tuukka:
I was thinking the same thing. Have you checked voltages at the rectifier board? Also: from what i gather, the connectors between the head and cabinet have a tendency to corrode/oxidize on these games. I know in my Sharpshooter there were several connectors that had some dull pins and some with a green-ish corrosion covering the pins. I ultimately wound up re-pinning all the connectors between the backbox and cabinet.
Also--you'll want to clip the battery off the mpu board as soon as possible. A memory cap can be installed in place of it. (Look up the procedure for that though, not sure if any jumpers need to be run or anything like that)
#4 8 months ago
Get that battery off the cpu board right away. Your boards actually look to be in pretty good shape.
#5 8 months ago
Quoted from frunch:
I did a search for the memory cap replacement. The Panasonic Super Capacitor was recommended and was rated at 1.5 farad, and 5.5 volts. Would this be a standard application for pinball battery replacement? (I'm referring to the rated values of the capacitor)
#6 8 months ago
Quoted from Playdium:
Yep. It's what I use on my Cyclopes. As long as you turn it on for 30 minutes every month you should be fine. https://www.greatplainselectronics.com/proddetail.asp?prod=CERS-1.5F-5V&cat=67
$ 399.95
€ 4.20
Buthamburg
PinBoss Mods
Pinball Photos
$ 48.00
$ 149.00
$ 35.99
Lee's Parts
$ 369.00
Sparky Pinball
$ 149.00
$ 22.00
$ 86.95
$ 49.00
Pixels Arcade Games
$ 89.99
$ 36.99
Yorktown Parts and Equip
$ 4.00
Z-connector (24 pin) Out of stock
Professor Pinball
$ 48.00
