(Topic ID: 285676)
Game of Thrones topper wings don’t work
By Rudy68
1 year ago
  • 5 posts
  • 3 Pinsiders participating
  • Latest reply 1 year ago by Rudy68
    #1 1 year ago
    Hi all,
    I have a problem with my GoT topper which I installed today. I’m pretty sure I installed it correctly following the Stern instructions I found here on Pinside. All the lights work but the Dragon itself isn’t moving at all. Sometimes I think the motor is trying to do something but I’m not sure. Could it be I switched the RJ-45 cables in some way?
    Because of a malfunction on my nr 8 nodeboard, the small dragonwings didn’t work as well. Could these two things be related? I hope someone can point me in a right direction to a solution. Thanx.
    Rob
    #2 1 year ago
    I'd contact Sterns tech support too.
    Anything in it's mechanism binding ?
    #3 1 year ago
    I will check tomorrow if it could be something “[email protected] TY
    #4 1 year ago
    Check the tail to make sure that it is not binding against the wings. Sometimes the tail can get pushed below the wing and pin it up. It should be above the wing, and pushed back so it doesn't bind. Some people need to use a little heat from a blow dryer to get it to move back, but be careful!
    #5 1 year ago
    Looking at the picture that doesn’t seem to be the case, but I will check it anyway, thanks.
