The battering ram shot on Game of Thrones needs a very hard hit to make it work. I'd say at least one in three shots fail. If you want to make it as easy as any other target switch shot here's how.
Picture 1. Locate the Battering Ram mount under the playfield and remove the top two red screws.
Picture 2. Now we're going to make a stop bracket. I found a junk flipper return spring bracket that is ideal for this. You can use
anything similar if you don't have one of these laying around.
Picture 3. Drill out the small spring hole to the same size as the larger hole and snip out any edges remaining.
Picture 4. Install the new bracket into position with the two red screws. Done. Your new Battering Ram stop is finished.
Picture 5. Shows Battering Ram in it's original position.
Picture 6. Shows Battering Ram in it's new home position with only about 1/4" of an inch between the ram tip and the target switch. This also opens up the ramp target switch next to it a bit as well.
This is a ten minute project at best. It's super easy to do, and now no more missed super jackpot shots due to a less than perfect hit on the ram.
