I ran into some issues with the game booting consistently. Fairly odd behavior...
When powered on for the 2nd,3rd,4th time ect. after putting in the desired "option" settings and then also after sitting cold overnight, the game would not boot the next day until I removed the batteries.
If I removed them and booted the game and set the "option" settings up again, the game would then consistently boot 10,15,20 times that day BUT after it sat overnight, it would not NEVER boot again the next day.
But, once I removed the batteries, all is well and the game has booted over 50 times with no issues now. Only annoying issues with this is adding credits but it holds 40 credits so, I'm just leaving batteries out.
I tried a different known good MPU, power supply, driver board, transformer, and different holders, different batteries (even a coin one) and am convinced that there is no solution to this odd problem. And before someone asks , yes I did use a diode in the battery holder.
I even had the same thing happen when on the test banch using an ATX power supply! So that eliminated every cause but for multiple tested MPUs... oh well.
Maybe NVRAM would "resolve" this but, I don't really care enough to use NVRAM and I fear that it would exhibit the same behavior if I ordered and installed it.
Just posting here to let other potential owners know of this odd issue. Seems to be MPU/settings/Flight 2K code related. I found some other chatter about it in the F2K owners thread so I am just assuming that I am seeing the same symptoms here, since Gamatron uses the same code.
