Hi all , Fixing a Galaxy pin for someone , game not here unfortunately
Weird issue is , Game works fine but after game has been on for 15minutes or so , Its start adding 10 points and the bonus raises .
After going into switch test when it started to self score , it was switch 18, 2x roll over buttons, they both tested fine ,
but I checked switch 26 , which is on the same line as 18. Blue Star stand up target ,
It registers as switch 18 at first but after holding it closed it then changes to 26 which is the correct no for that switch .
I cut the cap on that switch and no change, I also checked all other switches, they all seem good.
My feelings are its either cracked connectors on switch inputs on Mpu . or Even a bad diode on switch 26 .
I haven't looked at the Mpu and Sdu connectors yet btw , Although there appears to be some minor battery corrosion,
Someone has replaced the battery with a memory cap ,
I could try a Altek in the game to make sure that its caused by the Mpu or not
Any help would be great , it just seen strange that this only happens after the game warms up
Cheers
Ralph
