Quoted from Dwboca:So how do I get a set?
I will start working down the list soon and I will reach out with pm’s when they are boxed up and ready to ship. I only take payment when they are completed. Your already on the list.
Quoted from Loganpinball:I will start working down the list soon and I will reach out with pm’s when they are boxed up and ready to ship. I only take payment when they are completed. Your already on the list.
Awesome!! Thank you
Loganpinball I am guessing you can buy the ramps and the wireframes separately? I know I'm in line for the ramps, but I don't think I want to do the return wireforms at this time.
Quoted from KING-HENRY:Loganpinball I am guessing you can buy the ramps and the wireframes separately? I know I'm in line for the ramps, but I don't think I want to do the return wireforms at this time.
Yes. And I am only going to make 10 sets of ramps in total. Wireforms as many as requested.
I'm definitely interested in the ramps too, though knowing a ballpark price before I commit would be cool
Quoted from alleycat-pinball:I'm interested in a full set, ramps and wire forms. I've got wire forms for my Mando, your work is great.
Thank you. I appreciate that alot. Been in a funk (toy story) so thanks.
Quoted from atrainn:I'm definitely interested in the ramps too, though knowing a ballpark price before I commit would be cool
I have to build another set to figure out labor. The first set takes longer as I have to figure it out. I need to rotate a mounting point and make small adjustments. Once I have that solved I can see the average labor time by building a few of them. It is $50 an hour plus materials. My metal supplier has 303 stainless in large sheets of 20 gauge. It costs more than 304 which is carried by alot of venders. But, 303 welds better and is more durable. I also build off interested (lists), but take no money prior and you can always pass on it. I said limited ramps to 10 sets as they take a good amount of effort and time to make. I hope that helps or explains it.
Quoted from Markharris2000:Are you getting close to an estimate on the final cost of the ramps set?
Material costs just for the two ramps. Does not include labor.
The stainless plate is .96 cents per inch. (Includes taxes on the metal. Not shown in picture.
Left ramp:
$27.96
Right ramp:
$36.87
$63.93 total ramps material costs.
I will post labor times soon. I need to do atleast 2 sets to get average. I just want to demonstrate the costs of the ramps without the labor. Cutting, sanding,welding, polishing and playtesting adds up quickly. The toy story 4 slink plate mods takes 5 hours and is a miserable thing to build and I have grown to hate that machine as a result.
I dont have that same problem building the wireforms or ramps for gotg. I enjoy making them! A bucket full of hexagons made today..
536AF248-ACE5-4DEF-830F-0A1BAFC512F0 (resized).jpegCEE2BCB7-3092-4B9B-BFBE-91FCEA1D0C5B (resized).jpegFE582FE3-CBDE-4E74-89F5-391A90562954 (resized).jpeg
I put the plastic ramps back in. This is the $345 shipped version. I cut and shapped metal plates with guide holes for the wireforms to install on plastic ramps. The use of the existing adapter is incorporated. The adapter gets turned around and my adapter goes between the plastic ramp and the plate with threaded holes. Very simple and effective. I am going to make the requested wireforms first. Theres 15 on the list currently. After those are done I will make the ramps.
C7363028-4493-4751-A50C-E84868B85A05 (resized).jpeg88B60ECA-DE5F-45FF-B745-0751204FE61C (resized).jpegD95FE1D7-A29F-4566-8732-8AFEC4CEDEDF (resized).jpeg005A3E13-8483-4312-AB5D-61A34C22A5F2 (resized).jpeg94F7CE0A-CB92-4155-83D7-23CBC3E89453 (resized).jpegF7567F5D-C53C-4632-8E37-644F059D8E2F (resized).jpegD6D0D610-B014-4D54-918E-9B95DFBE7644 (resized).jpegE10C5319-3344-4100-9C31-9725D85DA3F4 (resized).jpegQuoted from spectrum-1980s:Can you see if I'm on the wire form list. I also would like to be on ramp list.
On it.
Quoted from PinballHaven:Great stuff man! Love the dedication to improving the great games.
Thanks. I just do not like plastic ramps. And these are huge.
I have to pick up more plates to make the ramps. As soon as I can get to my supplier I will and make the ramps to figure out the final costs.
Quoted from Yesh23:Can I get on the list for a set…. AMAZING work!
On it. Thank you Sir!
Using a tubular rivet press… wish I used this first.. i was using a punch and die set. Amazing tool on amazon..
Adding pictures here as this right ramp is made for timeframe.
Altered turning loops for better fitment. So far thats the first modification.
57944D48-265C-46FA-BD41-B142D7701F42 (resized).jpeg6629DBF2-AE32-4BD3-A489-54AD6CC49D68 (resized).jpegAE7AD0D2-B549-484C-B9A0-BE22151DE985 (resized).jpeg
287895C2-E624-477A-9D01-FB40D247A77A (resized).jpeg359F17FB-5726-4297-ABAC-7C3D72074801 (resized).jpegC37204B0-CF7F-4729-8385-E0144ED912C0 (resized).jpegI need help… I have left over led lights from Tron and that led to cutting patterns and back lighting… my proto ramps got hacked. I had to see it.
367270FD-0AB7-4352-80E8-53B788D2D066 (resized).jpeg6854F47B-FAA6-434A-ACB5-9E40A4247FA6 (resized).jpegB3C5912B-3149-407C-BFEE-7B7E3299DA0F (resized).jpegF6681B4F-9B3F-4E1E-A94E-B9A57DB1566A (resized).jpegQuoted from Loganpinball:I need help… I have left over led lights from Tron and that led to cutting patterns and back lighting… my proto ramps got hacked. I had to see it.
That's pretty frickin' cool. I am not sure if those cuts would interfere with ball travel, but it looks really cool. Perhaps you could be careful in your placement and NOT cut into the ramp in the CENTER of the ramp, so that the ball path would be clear, but the see-thru lines would be left and right of center line? I am guessing that the center 1/4 - 3/8 inch or so would need to stay clear, if the travel was any sort of issue.... not sure why we haven't seen metal ramps with illumination slots like this in the past (since plastic ramps have been illuminated from underneath for 30 years!)
Rush has cut name across ramp. As long as it is deburred and sanded it will not affect the ball travel. I can also move cuts to edges and the ball will not be able to roll over cuts. This was a idea that just hit me. No planning just see it mode.. looks amazing in person. My wife loves it.
8D99173B-561D-4DBF-BFA1-5769191DB5A3 (resized).jpeg172B30A8-DB3C-486F-93C8-BE7190F4784C (resized).jpeg2F935E26-42E8-40FF-9DF2-6201170C2D71 (resized).jpeg723F378B-71FE-4995-9A8C-0449C4EF7C35 (resized).jpeg737774A8-ACC3-42D3-BF4F-7A33D849E73E (resized).jpegLoganpinball that looks amazing..game-changer..BUT..are those just random cuts, or do these represent any symbols from the Orb, or anything else from the GotG film??? If it had something to do with the film, SIGN ME UP.
Quoted from KING-HENRY:Loganpinball that looks amazing..game-changer..BUT..are those just random cuts, or do these represent any symbols from the Orb, or anything else from the GotG film??? If it had something to do with the film, SIGN ME UP.
Just for myself. The outlanes show streaking energy. I cant mimic completed or it affects the ramps stability. I will do another variation of that when I have time.
Quick video;
Now you are just showing off. Those look sweet. Awesome you can use your creativity and put it to use like this.
Quoted from alleycat-pinball:Now you are just showing off. Those look sweet. Awesome you can use your creativity and put it to use like this.
Thanks, I prefer to call it artistic dementia..
Right ramp 5.5 hours with materials.
Total cost for right ramp:
$311.87
I will do left tomorrow. It is much smaller and will be less work. I give it my best effort and it cant be rushed. Hopefully this illustrates the process. Its a very large ramp!
4A5C2576-9ABE-489E-8550-0717E0833342 (resized).jpeg5BFA8914-7FC7-4AEE-A676-3C6807E6EC93 (resized).jpegCF9CAC97-17BB-4D5E-B5A0-FD3F41A73282 (resized).jpegB7BD52EE-B0CB-4B38-8519-DDE4A6BD296C (resized).jpeg029AE143-8E58-4BF8-B323-D5DE67F06B28 (resized).jpegF51A24D1-6000-4396-8F29-DD3B2B751215 (resized).jpeg68DEF3A0-EBDC-477A-BE97-3E182547DEA9 (resized).jpeg0366D00A-8618-466E-9BE8-8663F3F15ED5 (resized).jpegLeft ramp. Two hours in but getting close.
26D3E460-D279-442C-AD43-F205A8E84C71 (resized).jpegC332B981-19BA-49F5-ABA5-274DCD634E00 (resized).jpeg98DA8E1B-1B81-4287-AA6D-17C039EDFF7C (resized).jpegAB1749B8-2847-41CC-B33C-4CC47F276343 (resized).jpeg39BB6817-5FCE-4AAA-AEF1-D43886218BB9 (resized).jpeg38F9F53A-FEBE-4A3F-8A7E-3821410B5668 (resized).jpeg
Left ramp costs aee 3.5 hours with materials totaling $202. The labor is heavy with sanding, stoning and polishing as part of the build. Due to price and labor involved I am only going to make and sell 10 sets of ramps.
I will make as many wireforms as requested that install with the stock plastic ramps.
$345 shipped to U.S.
Limited ramps:
$818.87 and shipping will be determined to your address and will be added to total.
0A65B183-7BB4-4175-96AF-DC40DC65292F (resized).jpeg15AC9D7B-F5D2-4FEB-B797-06B4CF9B643E (resized).jpeg2D1C34D9-B8B0-4C92-8DED-3B0E60131D18 (resized).jpeg3563FBB3-7BB2-4AE5-BB14-B883D150CE2D (resized).jpeg72A7D8A5-3836-4520-8738-CF754F5C20C4 (resized).jpeg8A200586-9E31-43B3-8AF8-3CAB82003325 (resized).jpeg901DC941-4B54-48DF-9683-497838DB005D (resized).jpeg9F417F95-B130-4D1D-BCA8-4FA9D4424D25 (resized).jpegQuoted from KING-HENRY:I'm still in for the ramps..I'm at 98577 Raymond, WA
Awesome. Waiting on confirmations on another few that asked prior to price.
Set #1 test video. I fit and playtest everything prior to shipping. Got a bunch of combos on ramps. Right ramp backhand shots are a thing!
Please add me to the list of buyers for the wireform rails, please!
Added 16 months ago:.. For GOTG Pro, that is..
Quoted from Selig:Just picked up a pro over the weekend. Can I be added to the list for wireforms?
Yes I put you on it.
I have had a list of toy story mod requests going back 5 months. I have been doing Slink mods for a few weeks. I want to get the remaining Slink dogs done before I switch over to gotg. So, please be patient. I have been asked about eta and my best guess is gotg starting in early January. This is a family business of 3 and I am the only one designing, building and welding these mods. And right now I am seeing Slink dogs in my sleep…..
91856BDC-DA89-4E36-8938-452A45D2B38C (resized).jpeg99335A50-024B-4C99-AAC0-8A03CFDA4E00 (resized).jpeg
Quoted from Loganpinball:Yes I put you on it.
Thanks for update. I can spend my Christmas money on other pinball parts in the interim
I finished the run of toy story slinks. So, I will start these by next week. If your passing or changed your mind on these please pm me and I will drop your name off the list. I have had alot of issues with no replies with the Slink mod. I built the list in large groups. It really bothered me that 8 people have ghosted me on them. Thats 32 hours of work I could have used here.
I have no issues with dropping your name, just let me know. I will build these one set at a time as a result. Again, if your out just let me know.
And thanks to a pinsider I think I need to add a blocking post or wall on the left return. If the ball jumps onto plastics it just runs right down to the side drain. It has not happened playtesting, but an airball jump will roll right down to that side drain. I will add a piece to kick it back into play.
Quoted from rwmech5:Looking good, I need these wireforms on my game!
Trying my best.. I finally found a Acdc and that was one of my dream games to do. I burnt 20 hours on that this week, sorry for the delay. When I see a design idea in my head I have to make it..All gaurdians now until the list is done.
543777A3-DE3B-4BB2-AA6D-D332350AA87F (resized).jpegF8D174B2-2F11-46DA-8690-9EE5F9A3A29B (resized).jpeg
Weldind studs over using plate for flashers. I did it on acdc and I prefer that look over the plate.
7A4026DC-13F4-4E92-90D1-3EB2F57AC2AB (resized).jpeg9C42FE7D-DD85-4760-8FDF-90A8336549F4 (resized).jpegC3852822-DAF5-4B57-B0CC-529F211C3899 (resized).jpeg
1AEDB53F-078B-4054-BC25-41AAB25FCE94 (resized).jpegVersion 2 completed first set. Changed mounting points, flasher mounting and hexagons. $345 shipped to U.S. only.
43BF85AA-9FC8-4E35-B28A-B0846262049B (resized).jpegA9A7A565-9BC8-4A0A-8EA4-F86B7FBB484E (resized).jpegEF903C21-97CF-45FC-836C-68FCBA283092 (resized).jpeg85D98174-74EA-4FA3-8E26-5D3376416322 (resized).jpeg5A9EBEAC-4F01-4105-BBFB-AEFA46664EC1 (resized).jpeg5169C6FE-B5C1-410F-879F-602561CCA726 (resized).jpegD408C806-82FF-4D88-8BF3-80C1E96D4E1E (resized).jpegED9F7901-8538-4935-9272-B50FA74C2796 (resized).jpeg
This page was printed from https://pinside.com/pinball/forum/topic/gairdians-of-the-galaxy-wireforms-replacing-the-plastic/page/5 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
