Instructions to install ramps:
Turn off machine and remove the balls. Do not do any part of this with the machine tirned on. Bad things can happen electrical shorts being number 1.
1: Remove both ramps and wiring to flashers.
2: Remove flashers from the ramps. Place plastic dome on top of wireform platform while placing the flaser board underneath wireform platform see pictures. Center the flasher on platform, ensure flasher board is centered and tighten the retaining screws.
3: Remove the two front sling plastics and rubber ring. Then remove the front sling stud screw completely and set aside.
4: Raise the playfield and thread the included 3 inch screw into the the playfield threaded hole insert. Tighten that screw until it is flush with the bottom of insert and tight.
5: Lower playfield and put the plastic spacer over the screw that is now sticking up above the playfield. Put one of the included washers over the spacer and then install the nut down to the spacer and make sure it is tight. Verify the spacer is locked down and not loose. If so tighten, it just needs to be snug, so dont go crazy. Then place the large washer (plastic protector one) over that nut. Put rubber ring back over the sling, then place sling plastic back into place. Place included washer or reuse original washer over sling plastic. You should now see a secured stud sticking up in the front.
6: remove the 2 screws that are holding a square metal plate on each of the plastic ramps by backbox. Take one of the included plastic adapters and place it underneath the ramp to align with the two screw holes. The holes on the adapter are threaded. Just hold adapter under the plastic ramp and install the 2 screws that you removed into the new adapter. The bracket has a L shapped design with a cut out on it. You want the cut out facing you or towards the front of the machine. The rails will instert into this cut out. The 2 screws just need to be snug. Try not to over tighten them.
7: Install the right ramp by placing the wireform into the cut out opening in adapter while aligning the other mounts on rail so they all are lined up. Start at the sling. The bracket should be hung over that new installed stud. Place included hardware large washer and included smaller washer over the stud. Install the threadlock nut down the stud, but leave it loose for now.
Next, use included screws and washers to go through the metal brackets on the rail into the existing squared mounting bracket studs on playfield. You want all three of the mounting points started but not toghtened. Look at rail and center the ball drop hole on lower end of rail to be centered in the lane. When its centered tighten that thread locked nut down until it is secured. Now tighten the other bracket screws. You can move the rails around for alignment if needed. Make sure all the mounts are tight you also need to thread flasher wiring through playfield.
8: install the left ramp in the same manner as the right. Same procedure as above. The left has two mounts, sling and one mid bracket. You can reuse the spotlight screw or replace it, but that spotlight is part of mount on rail now.
9: raise the playfield and plug everything back in.
10: put balls back in and play the game. The rails are very adjustable in the drop. I playtest them on my machine and they should be good for you. If you need to adjust them you can lightly bend the upper rail up or down in small increments. There is a sweet spot. The upper rail not only stops the ball, but it also strikes the top of it sending it downward.
