A week ago Friday I was working on my SS at the arcade bar I tech for. (A few of the games belong to me, Elvira is one of my babies.)
One of the pop bumpers broke and while I was out to purchase new lock nuts for the skirt ring my apprentice tech fired it back up and things did not go well.
He said the lights went weird and then the G10 error came up.
A friend recommended changing U14 and U24, which I have done. In fact, there was a bit of that old electrical odor around that spot that seemed to go away after I removed one of them.
My usual suppliers don't even stock those chips anymore so when I found some I bought 20 chips and a bag of sockets too. Hoarding for future repeats or to help someone else down the road I guess.
Changing them was not pretty. I had a ridiculous time getting the solder cleared from the vias. I recently purchased a desolder pump, but I guess it's time to get a real Hakko or something because this Chinese deal isn't cutting it on precision work....
For the second chip I just cut the chip free from the legs and soldered the new socket on to the old legs instead of trying to pull them out and clear the holes. Looks a little hokey but the connections are good and I didn't lift any traces/vias on that one.
I thoroughly checked all the traces and repaired the ones I damaged in the process and when all was said and done I went to try my board in another machine... Still get the error. (Tried in another machine to rule out any still existing shorts etc. Once I get my board booting I will carefully go through my wiring before putting it back in Elvira.)
At this point I'm kinda hoping its the G10 chip itself that is still bad, as there is someone relatively close to me that has a couple available and I won't have to worry about installing another socket/soldered chip.
However, I've read there are a few more potential culprits in the mix: u23, u13, u5.
My question for those in the know:
Is there any risk to the "donors" to swap good known security chips and ROMS on to my board, or putting my G10 and game ROM on to another board for testing?
If I end up ruling out the G10 chip, is there a way to definitively determine which other component is bad so I don't waste any more time guessing?
I have access to an Attack from Mars and an NBA Fastbreak, but the boss will only let me swap parts if it is deemed safe for his games. Doesn't want to risk taking one of them down too.
Also, once I get the board working, will the game even power the lights and solenoids without this board plugged in all the way? Does the other board power the solenoids and this one just the switch matrix....just trying to figure out how to best be sure I've cleared any shorts before blowing chips AGAIN. If I can let the solenoid power through without connecting the switch matrix connectors back on I could probe for higher voltage in addition to visually checking for shorts.
Probably only need to check right around that pop bumper, but I'd hate to make a $40+ assumption there...
Thanks so much!
-Eric
