Quoted from Quench:What do you mean about your noise getting lower? There shouldn't be any to begin with.
I was having trouble getting waveforms not to be a mess (you thought that maybe my ground wasn't connected). At first I thought it was noise or something on the machine, but as I played around with the ground lead and got it better connected, the waveforms cleaned up. So my whole rabbit hole about noise may have been a red herring. Did I just mix metaphors? I'm starting the day perfect.
Quoted from Quench:I see you're using an Alltek Solenoid driver board. I believe their 5 volt power is a switch mode power supply (SMPS) which operate at high frequency and can generate noise.
So, have you have a Bally solenoid driver board you can try - their 5 volts is generated by a "linear" regulator which doesn't generate any high frequency noise.
I do have a Bally solenoid driver board! It's not bulletproofed or refreshed in any way, but it works. I'll put it in today and take some more measurements.
Quoted from Quench:Isn't this telling us something? When you say "free floating", do you mean not screwed down?
In a conversation I had with Alltek, one of the suggestions was to isolate the LDB from the backplane ground, just to experiment, so at one point I had the Alltek screwed down and the Bally "floating" in front of it loose. Didn't make any difference to anything, but when I was chasing those ugly waveforms I thought maybe it had something to do with it...It didn't.
Quoted from Quench:One other thing, I think you mentioned earlier at some point that when the game gets warm less lamps flicker. Have you tried using a hair drier to work out what item being heated is affecting the flicker?
I would, but given I've swapped the MPU and LDB in various combinations, I feel like I'm chasing my tail. The only thing I could really try is the rectifier, but why would the rectifier getting warmer impact the voltage from the MPU to the LDB? Anyway, feel free to suggest heating up anything, I'll look like a fancy hair stylist and run around this thing with my son heating every element if that gets us to the solution.
Quoted from Quench:Sorry which board J2 and J3 you're referring to?
I was talking about the LDB. Maybe I've got my connectors wrong...Top left and bottom left, the only connectors on the LDB we need to perform the test. The lower left brings power, the upper left to the MPU (maybe that's J4).
