New! Dark mode!
(Topic ID: 208174)
Future Spa: Father and Son's Second Restoration [COMPLETE]
By jsa
2 years ago
  • 682 posts
  • 58 Pinsiders participating
  • Latest reply 1 year ago by Bryan_Kelly
  • Topic is favorited by 59 Pinsiders
There have been 408 images uploaded to this topic. (View topic image gallery).
There are 682 posts in this topic. You are on page 14 of 14.
#651 2 years ago
Quoted from Atari_Daze:
Actually yes, you should request a power quality study be provided by the solar power company. Your results have ramifications they need to consider. Your product that was effected is a pleasure device, what about those on life saving electronic equipment. They should be very interested in providing a product to the market that can filter out such harmonics?
The company that makes my equipment (sort of a more sophisticated Tesla Power Wall) is shipping, but while we're adding features and taking notes I'll keep it private. They make a fantastic product. I'll work with them for some possible solutions that can be integrated into their next revision.
However, for my current setup, I'll need something inserted into the architecture that doesn't create additional load or other issues. The solar company that helped install the panels, while awesome, are out of the loop in this case. We went outside their normal equipment to do this.
Quoted from Kawydud:
Such an epic thread for diagnosing a problem. Congrats to all who pitched it.
Inverters can cause a lot of havoc, I work with large ones that run industrial compressors. If you don't have a line reactor filter installed, the building will be seeing all sorts of electrical problems.
For a home, though, there has to be a solution that is more residential-scale. I'm surprised this isn't more of a common situation that there wouldn't be some easy solutions.
#652 2 years ago
Is this the new inverter testing device?
#653 2 years ago
While I greatly enjoyed your entire Future Spa restoration thread, the deep dive into troubleshooting this seemly little gremlin borders on epic - so much to learn and absorb here!
#654 2 years ago
Quoted from ReadyPO:
Thanks, totally agree on the learning. It doesn't hurt that this Future Spa is pretty fun to look at while you're doing it.
#655 2 years ago
Quoted from jsa:
No flicker.
We solved it.
I'm speechless. I need to take this all in.
Sweet Geebuz.... I too am beside myself.
Time to look at filtering the AC to get that 20kHz harmonic out.
Or maybe trying to modify the zerocross circuit to only fire once.
#656 2 years ago
Quoted from Zitt:
I'm thinking that since it seems to only effect old Bally machines, perhaps I should get an isolation transformer for the machine for now, and just get the inverter company to fix this.
#657 2 years ago
Quoted from jsa:
Hmm, why not one sized for the whole power supply to your residence? I mean if YOU'RE not the one going to pay for it.
#658 2 years ago
Well, you can't really use isolation transformers for a whole house. You can do massive UPS systems or line conditioner systems...but your mileage may vary.
Your best bet is usually eliminating the noise. That's why I'm trying to get the inverter company to dig in to this one.
#659 2 years ago
Quoted from jsa:
I'm wondering how effective a simple ferrite bead would be inline on the 43VAC zero cross circuit:
Maybe getting one of those multiturn beads he showed would go a long way to reducing the 20k harmonic.
#660 2 years ago
Quoted from Zitt:
I guess the question is, where would you put it exactly? After the rectifier on its way to the SDB?
#661 2 years ago
Quoted from jsa:
No. I'd put it after the rectifier but before the zerocross in the MPU.
IE so the CPU doesn't get interrupted until it's really suppose to.
See https://pinside.com/pinball/forum/topic/future-spa-father-and-sons-second-restoration/page/12#post-4651214.. you'd want to remove those early pulses with some kind of filter network.
I'm not a filter designer by trade... but it "should" be possible to design a low pass filter centered around 120Hz which would reduce the 20KHz harmonic.
#662 2 years ago
Quoted from Zitt:
I guess you mean on the ZC line between the rectifier and the MPU then, if I understand correctly. I have ferrite beads designed for this purpose, actually. Don't ask me why, but you never know when you might need one.
#663 2 years ago
Quoted from jsa:
correct; I have doubts the frequency response of a ferrite bead will be enough to attenuate the 20kHz signal.
A quick calculation using:
http://www.calculatoredge.com/electronics/ch%20pi%20low%20pass.htm
with:
5kHz cut off, 5ohm Zo, and 20db ripple with 3 components shows a pi filter with 190uF caps and a L of 14uH.
I haven't pspiced the pi filter... and I'm not sure how it will impact the zero cross.
#664 2 years ago
Quoted from Zitt:
with:
I actually do want to tell you I have any idea what I'm seeing here, but I'd be lying.
#665 2 years ago
I'm so happy that other Pinsiders jumped in to help you figure this out. I was no help at all because I'm a dummy when it comes to electronics and it was all Greek to me. Congrats.
#666 2 years ago
This is among the coolest troubleshooting threads I have ever seen. I don’t usually pay attention to these, but started getting interested over in the Bally thread, and followed when it got brought back here. I was simply stunned when you were asked about solar inverter (“that’s really pulling stuff out of thin air” I thought) to see the “actually, yes” answer... Truly epic, and glad you got it figured out!
#667 2 years ago
Thanks! It couldn’t have happened without this generous group of people here.
Today I tried an isolating transformer.
Problem is entirely gone.
Tomorrow I’ll see what happens with a ferrite choke and no isolating transformer (though until I get the noise eliminated at the source, I’ll probably keep using the isolator to protect the game).
#668 2 years ago
Which isolation transformer did you use?
#669 2 years ago
Quoted from pintechev:
The one I already had:
#670 2 years ago
That’s the one I have!
#671 2 years ago
Quoted from jsa:
Gotta like a plug'n'play solution
#672 2 years ago
Quoted from jsa:
Did you replace the main AC filter on that machine? For $20, it is something that should never get skipped.
This what I used on my Mata Hari:
You can see the differences.....
Yves
#673 2 years ago
Quoted from Arcane:
Yves
Yes, here is our original:
...and here is our replacement, which we sourced from Marco:
Not quite as big as yours. Anything remarkably different?
#674 2 years ago
Quoted from jsa:
The only thing I can see is the current capability (6 Amps versus 5 Amps) and the double filtering versus single stage on yours. On a wide body machine, there is more electrical consumption than a narrow-body, due to the some additional GI lamps and extra switched lights. The double stage may also helps if your electrical supply is dirty in California. These filters were installed to prevent parasitic oscillations and interferences generated by the pinball to go back into the main supply, but they work in both directions, due to their symmetrical design.
I sourced the filter I used, from Digi Key.
I am glad that you found a solution for your unnerving lamps issue. After all the care and labor you put in that machine to restore it to pristine condition, that was very demotivating. If you ever get a beefier filter, try it and see if you can get rid of your isolating transformer.
Yves
#675 2 years ago
Quoted from Arcane:
Yves
On one hand, I'm disappointed that the original line filter or my replacement of the same level won't do the trick. On the other hand, Bally could not have predicted the weirdness that is my solar panel and inverter setup back in 1979.
I've been meaning to do some experimenting with ferrite cores but I'm so tired of pushing trifercons out of box connectors that I keep procrastinating. I'm feeling this is pretty done! Time to celebrate.
#676 2 years ago
In her new location, at least for now:
If you look closely, you can just see a little purple coming out the neck grill... just a little extra flair for dark rooms.
#677 2 years ago
Quoted from jsa:
That is so pretty I'd be afraid to touch it.
#678 2 years ago
Quoted from MustangPaul:
That's the thing, fiberglass resin, automotive paints... Holy crap, this thing is a tank. I wonder how much this machine weighs in comparison to before the teardown from bondo, fiberglass resin, paint and clear.
#679 1 year ago
What would be really cool is if you could get the lights to flicker!
#680 1 year ago
Quoted from jsa:
Weigh it.
#681 1 year ago
Quoted from JethroP:
I literally just spit my strong and overpriced alcohol across the room.
#682 1 year ago
Damn nice. Or....damn, nice! Either works.
$ 9.00
Cabinet Parts
Third Coast Pinball
Third Coast Pinball
$ 149.95
Allteksystems
$ 85.00
nvram.weebly.com
$ 49.99
PinballElectronics.com
$ 8.00
Third Coast Pinball
$ 9.00
$ 149.00
