Quoted from jsa:Well already there are some differences for sure. The original is a AS-2518-49. The repro is closer to a AS-2518-18, but they are supposed to be compatible. The one main difference is the feature lamp fuse on the -18 is a 10amp fuse, and on the -49 is a 20amp fuse. So I'm running the feature lamp bus on 10amps, but I can't see the difference that would make other than blowing the fuse if I push it too far. If you look at connection point E9, you can see that the original board had a place for two wires to terminate. For the repro, I twist those wires together and go into a single connection point.
Just for reference, here is a photo of my original board:
Here is the new board:
The new board sure is pretty and well organized!
But the old board is certainly good enough to be cleaned up and put into service.
It would take a couple hours to completely rebuild it, but it would work well.
definitely a difference in current flow from 20a to 10a.
Definitely a minor current difference on connection E9, but still a difference.
Maybe send the old board out for rebuilding if you dont feel confident. Its super easy with a proper station and tools.
But I would do nothing until I test it in your existing game as it is. I wouldnt add any more random issues while troubleshooting.
