Hi all, I just finished a playfield swap of eight ball deluxe, plugged it in and it came up, but none of the switched lights were on. I went into the test mode and started cycling thru the tests, the free game knocker fired but no other solenoids. The fuse under the playfield was out (1amp MDL slow) which is for the solenoids I believe, and there was a smell. I replaced the fuse but it blew again immediately after starting. I checked all the coils for resistance and they were all above 2.5 except the coin door coil, which is at 0.5. Can this coil cause a problem if it gets shorted?
Thanks,
Karen
#eight-ball-deluxe
