Hello there.
I have a fuse question about my DataEast MNF. I blew F5 fuse which knocked out my flippers. I am having trouble finding a Buss MDX4 125V fuse. Question 1: Are MDL and MDX fuses interchangeable on pinball machines if the amperage (4) and voltage (125) is the same? If not, where can I find an MDX 4 125v fuse? I am also having issues with the gutter switches that I think is related. All three switches pass the continuity test with the volt meter but the game is registering missing ball(s) when turned on. (I did have a 4Amp 32V fuse in when trying the switch test but it blows when a flipper is pushed, obviously). Question 2: Does anyone know if the gutter switches would also be affected by the blown F5 fuse installed or 32v fuse in its place? I ask because if I need to order parts I was thinking I could get them all at once. BTW, the switch test failed on the gutter switches and all other switches pass testing. Thank you in advance so much for any guidance!
