I need some help figuring this one out - the F109 fuse (4 amps, 250 volts) keeps blowing on my TOTAN CPU. Mostly, it melts right away during boot up, but last night I was able to play for a full half hour before it blew. When it does blow in the middle of a game, here's what happens:
1. The flippers stop working
2. The ball eject keeps firing, trying to kick out all the balls into the shooter lane
3. A few seconds later, the DMD goes blank
Everything else works fine - sound, lights, etc. Fuse F109 appears to get power directly from the transformer. The manual specifies T-series fuses, but I've also tried GMD's. Switch tests are all normal and There doesn't seem to be a particular feature that sets it off.
Any ideas about what I should be checking? Thanks!
