(Topic ID: 231404)
Fuse Holders Where to buy good quality
By MarkAnderson
6 months ago
  • 5 posts
  • 5 Pinsiders participating
  • Latest reply 6 months ago by G-P-E
    #1 6 months ago
    Where do you buy single or possibly multiple fuse holders that will last. I found a few on flea bay but they are low quality made in china and will probably have good occlusion of holding a 6 x 30 fuse for about 6 months and then I will have to replace it. I found some Standard Motor products ET222 holders but they need to have the leads screwed on. They cost $10 for for of them in a block and I cut them into singles unless I am replacing a whole block but it seems like there should be better items out there that are as durable. Is there anything at Menards or Home Depot or a pinball parts seller website?
    #2 6 months ago
    I normally use Bussmann BK/S-8002-1-R as a good, general purpose fuse holder.
    Several electronics suppliers have them.
    If you're trying to match Williams fuse holders specificially, look for littlefuse 03540101ZXGY
    Don't use a flat strip like you have pictured. That type has a high failure rate. The tabs can only bend so many times before wearing out and snapping off.
    #3 6 months ago
    Digikey
    #4 6 months ago
    Great Plains.
    #5 6 months ago
    Avoid tin plated brass for anything of 'sufficient' current draw, the tin plated brass fuses should never be used for 8 amps or above (I use the tin plated berylium copper fuse clips everywhere).
    As Forflow mentioned - Littelfuse and Bussmann are good brands.
    If you want solder lug variety - try Littelfuse 035400xxZXGY where the xx = number of ganged fuses. Most popular is the single fuse holder - 03540001ZXGY. Bussmann BK/S-8002-x-R is also good, replace "x" with number of ganged fuses. Again, the single BK/S-8002-1-R is most popular.
    Board mounted variety (singles only): Littelfuse 03540101ZXGY is the easiest to find.
    When looking for fuse holders, check the base metals:
    Tin plated brass = low current
    Tin plated berylium copper or tin plated phosphor bronze = higher current capable
    Chinese fuse holders tend to be some sort of tin plated pot metal.
    $ 36.99
    $ 60.00
    Playfield - Plastics
    Vandelay Industries
    $ 65.00
    Whitewater pinball mods
    Medisinyl Mods
    $ 200.00
    Professor Pinball
    $ 48.00
    $ 28.00
    The MOD Couple
    $ 199.99
    3D MODS
    $ 89.99
    $ 29.99
    $ 69.99
    $ 86.95
    $ 45.00
    Sparky Pinball
    Bright Lights Pinball
    Apron Envy
    $ 99.99
    $ 38.00
    The MOD Couple
    $ 49.99
    $ 11.95
