All of a sudden a my shoot 1 and shoot 2 coils stopped working in Fastbreak. These are for shooting the basket in position 1 and 2. They share a common wire red/vio. I traced it to a blown F118 fuse. If I replace the fuse it immediately blows again when either of those 2 coils attempt to fire. I removed the connector supplying power to the coils and when I run the coil test the fuse doesn't blow. I assume this means the board is ok and it's a problem with one of the coils or wiring. I can find no shorts or cut wiring or anything wrong with the wiring to those two coils.
Any ideas what to try next?
