(Topic ID: 252249)
Fuse Blowing on rectifier board.
By pinballnoobie
9 months ago
  • 11 posts
  • 6 Pinsiders participating
  • Latest reply 9 months ago by V_piscopo
    #1 9 months ago
    Got a bally xs and os with a new rectifier board. The 4amp fuse blows when I installed and turned on. Any idea what this powers? What could cause the issue? Thanks
    #3 9 months ago
    F4 looks like it's the solenoid power, disconnect everything from the solenoid driver board replace the fuse turn it on and see if it blows. If it does, suspect shorted bridge on the rectifier board. If it doesn't, you likely have a locked on driver transistor for a solenoid you need to track down.
    #4 9 months ago
    The rectifier board and the solenoid board are both brand new. When the solenoid board is not hooked up the fuse is fine. Where are the driver transitors for the solenoids? What does it look like? How to tell if its locked on? Thanks
    #5 9 months ago
    You can plug in one plug at a time on your solenoid driver board (while game is off) And figure out what plug(s) are blowing the fuse to narrow down your search.
    #6 9 months ago
    The drive transistors for the solenoids are on the solenoid driver board. With power off, Remove F4, power up and go to switch test and see if there are any switches closed that control the solenoids, such as pop bumpers, slingshots, etc. Report back
    #7 9 months ago
    New solenoid board. Why would any be bad or locked on? The only time when it blows is when the top right connector is hooked up. I got no 12v or 5v on the new solenoid board.
    #8 9 months ago
    It's best to use the connector identifier. Like J1, J2, etc. And specify the board(s). Sounds like you have a dead short somewhere.
    #9 9 months ago
    How do the connectors on the new rectifier board look? Can you post a pic?
    #10 9 months ago
    P3 connector. The molex looked a lil corroded on the wire harness that plugs in to the rectifier. Could this be an issue? Any tips on how to clean without taking apart? Not at machine to take pic.
    #11 9 months ago
    You can try to hit it with an old tooth brush but if any of the pins on that connector are damaged they will need to be replaced. And if your replacing one you should replace them all. Snap a pic next time your at the machine.
    CzTV Mods
    Various Novelties
    GC Pinball
    $ 115.00
    Cabinet Parts
    Merf's Pins
    $ 9.99
    $ 29.00
    Filament Printing
    $ 999.00
    $ 159.99
    Great American Pinball
    $ 65.00
    G-Money Mods
    $ 5.00
    Metal-Mods
    $ 69.99
    $ 89.99
    $ 40.00
    G-Money Mods
    $ 18.99
    $ 48.00
    $ 200.00
    Professor Pinball
    $ 4.49
    $ 11.95
    $ 395.00
    M&M Mods
    $ 48.00
    Metal-Mods
    $ 39.00
    The MOD Couple
