(Topic ID: 13162)
Funny newby SM problem
By DCFAN
7 years ago
  • 9 posts
  • 7 Pinsiders participating
  • Latest reply 7 years ago by DCFAN
    #1 7 years ago
    I have been playing my SM that I got NIB for a few weeks now. I had a couple of minor issues that I had to fix after taking it out of the box such as a tight right flipper mechanism that had to be taken apart and loosened, and a pop bumper that was too sensitive that needed a switch adjustment. Really I have had no big issues and have even done a quite a few of the common mods.
    Now for the funny part. I have been playing the game for over three weeks thinking that everything was working ok. However, it turns out that there is a problem with the Dock Ock shot. I have been noticing that quite a few of my Dock Ock shots hit the blue bumper at the bottom of Dock Ock and bounce back. I had been thinking that was part of the game and that the Opto was recognizing those shots. The newby that I am just realized that the magnet core is slightly raised on the playfield and is causing shots that are supposed to go into the VUK to jump off the magnet core like a ramp and hit the blue bumper and not register as a hit. DOH!
    Anyway, it looks like the magnet core has a screwdriver end that just needs to be turned to lower the magnet so it is no longer above the surface of the playfield.
    Live and learn. No wonder I was struggling to get better at this game. I guess I got lucky when I got a 280 million score with Dock Ock shots not registering.
    #2 7 years ago
    Quoted from DCFAN:
    That is a good score.It looks to me like you can adjust the magnent core without any trouble.
    #3 7 years ago
    The magnet can be adjusted. However you may have to remove the assembly and put it in a vice
    or heat it up to get it to move. My Spidey had so much blue loctite on it, it was impossible to get
    it to move while it was in the game. Maybe yours isn't as bad. Good luck.
    #4 7 years ago
    Quoted from RJW:
    +1 on that for me. I ended up taking it out as well using some lube and it took some real effort to get it to budge. If yours is anything like mine was you will most likely have to take it out to be able to freely adjust the magnet height. Good luck.
    #5 7 years ago
    Thanks for the info on the magnet. I will update tonight.
    #6 7 years ago
    Quoted from The_Dude_Abides:
    RJW said:The magnet can be adjusted. However you may have to remove the assembly and put it in a vice
    Same here, I had to pull it and put the torch to it to break it loose.
    They really didn't want that thing to move.
    #7 7 years ago
    Mine was raised but fortunately not mushroomed so that I could remove the assemble. The nut however was not going to come loose. I ended up sanding the core flat on the top - sanding a bit and fitting it to make sure it was good - rather than trying to pull the core out of the nut.
    http://pinside.com/pinball/forum/topic/doc-ock-fixes
    #8 7 years ago
    GOOOOOOOO STEEEERRRNNN
    #9 7 years ago
    I just finished fixing my raised magnet core problem. Luckily I own industrial sized sockets. I knew I owned those larger sockets for some future endeavors. I have owned that tool set for 15 years and the larger socket wrench set has probably only been used maybe 5 times on automobiles. I think the size of the nut that holds the core was 1-1/8th inches.
    The nut came right off with hardly any effort with the socket wrench and I did not need to take the mechanism off of the playfield.
    It took a couple of minutes to set the core at the right height and then I just gently tightened it back up with a minimal force so as to not damage anything.
    I then took a round stealth protector and covered the top of the core to protect the playfield.
    I played a couple of practice games to test the shot and it is smooth like there is no core now when the ball travels across it.
    Also, I installed the pinbits little round deadener pads in the Dock Ock hole at the bottom and back and did not have any bounce-outs on firm shots.
    $ 44.00
    $ 18.99
    $ 14.50
    PinballElectronics.com
    $ 99.99
    $ 66.95
    $ 800.00
    Playfields
    Pinball Playfields
    $ 49.99
    $ 45.00
    Sparky Pinball
    $ 7,500.00
    Great American Pinball
    $ 135.00
    $ 26.50
    The MOD Couple
    $ 7.49
    Yorktown Parts and Equip
    $ 5,599.00
    Ghostbusters Pro Out of stock
    Operation Pinball
    $ 93.00
    $ 90.00
    Lighting - Under Cabinet
    £ 49.00
    PinballToys
