Hi,have gottlieb funland.on start up game score reels started acting up.now I have no power to reels.can someone show me on schematics the correct path to search for issue.thank you.
Your Post needs some clarity. No power to score reels? Or acting up?
Assuming the game starts up what do the score reels do when a playfield switch is hit?
Or how far along does the reset sequence progress when starting a new game?
Hi Phil lee,the start up sequence was almost normal.when hitting switch on playfield ,at first points,now nothing.i was wanting to know if someone could show path on schematics as place to start looking.again thanks for replying.
Hi pinballbrian
I do not have the schematics - I am not so good in "old pins" - I am not so good in ONE-Player-pins. I show from a snippet from pinside - encircled red is the area You may have troubles. I do not know how the schematics is drawn (plugged-in ?, game started ?, at game-over, ? etc.) - have problems (red question mark) with switch "D" , also with (red q-mark) switch on Ball-Count-Unit --- any way - when You have started a game (BE READY to toggle-off, unplug main power cord) press the armature on N-1-Point-RELAY - does the Score-Drum actuate ? With this we learn about "R-Relay pulling or not pulling, Switch "R" in the encircled red area.
When You have started a game () close a Tilt-Switch - does the T-Tilt-Relay actuate ?
When You have started a game () close the Outhole-Switch - does the O-Relay fire ?
When You have started a game () close the Ball-Return-Switch - does the Add-Ball-Coun-Unit fire ? Greetings Rolf
Hey,thanks Rolf.i will look at that.again thanks.i will post what I discover.as there is not much posted on this machine in forum.
If the reels reset at start up, you have power to them.
You will have no power to anything until the ball count unit steps up to ball 1. Is that happening?
Ok,after a little work,hold coil wires were frayed.resoldered wires.cleaned switches on ( D )reset relay.game will start.Problem now.game will end on 5th ball,light on glass says last ball in play.5th ball lights up.but no power to table.any suggestions.again thanks guys.
Hey guys good news,machine is working correctly except for score reels,I had to shop the ball count unit and turn a game over switch stack around. ( my mistake),when shopping it.OK,PROBLEM.score reels do not reset on start up.they nudge when hitting playfield switches,but do not move.i feel that is in relay adjustment,my main concern is reels resetting on start up.again any other suggestions where to look and again thanks for helping out.
This page was printed from https://pinside.com/pinball/forum/topic/funland-no-power-to-score-reels and we tried optimising it for printing. Some page elements may have been deliberately hidden.
