(Topic ID: 233159)
Funhouse won't boot
By apscarpelli
1 year ago
  • 12 posts
  • 8 Pinsiders participating
  • Latest reply 1 year ago by Zablon
#1 1 year ago
Been sitting for some time (year or more) and worked 100% and came down to play it with it not booting when powered on. Just a hissing sound from speakers. All LED's are on besides LED3 on Power board. Check all fuses and all check out.
Here are the numbers I got from test points.
TP3 11.85
TP2 5.13
TP1 12.79
TP8 18.36
TP6 75.2
TP7 22.2
Any other areas to check? Would like to find root cause before i take out the boards and send them in.
#2 1 year ago
Did the batteries leak alkaline while it was sitting? If so, could be the culprit.
#3 1 year ago
I'd reseat all of the connectors especially the ribbon cables. Just pull 1/2 way up on each and push back down. No need to remove completely.
#4 1 year ago
Rudy is probably just upset you haven't played with him for over a year.
#5 1 year ago
I just posted a few seconds ago about issues with my Funhouse.. must be the night for it. Sorry I can't offer suggestions but I will trade your TP2 voltage (5.13) for mine (4.9) in exchange for the boot up.
Dave
#6 1 year ago
Reconnected all pins/ribbons in backboard. No luck. Pulled all fuses to test for connectivity and all good, except I busted a cap off one of them (F105). New batteries I put in within last few months and no corrosion at all.
Any other ideas?
#7 1 year ago
#8 1 year ago
D19 is solid, D20 never comes on, D21 stays on.
#9 1 year ago
Found corrosion on the CPU board.
#10 1 year ago
Sending CPU board into Clive. Going to also send in Power board and sound board while I am at it.
#11 1 year ago
Yeah, when my NGG started not booting in the middle of last year, I eventually tracked it down to a bad MPU board due to battery corrosion. The batteries only get used when the machine is powered off. The longer your machine is powered off, the more often you’ll need to change the batteries. That was new information to me at the time.
Battery corrosion is an insidious issue that’s difficult to immediately diagnose and it starts causing all sorts of crazy seemingly unrelated issues, when in fact, they’re all related. The machine usually starts exhibiting some odd error/behavior as the corrosion expands and results in an eventual total shutdown. My battery corrosion was not visible until I pulled the board and inspected the back of the board.
I wound up replacing the board (w/ ASIC chip), transferred over the processor, ROM, and security chips and it’s been solid ever since. On the new board I installed the external battery compartment. I now use lithium AA batteries (not supposed to ever leak), not alkaline.
https://pinside.com/pinball/forum/topic/no-good-gofers-test-mode-function-buttons-not-working#post-4502288
#12 1 year ago
While you have the board sent out you should have him just add an NVRAM chip to it then you won't have to worry about batteries. They are only $15-20. It's a bit of a pain to install on this board because the traces are so small so I don't suggest doing it yourself unless you are really comfortable with soldering. In the end though it is very much worth it.
PinSound
$ 219.99
PinballBulbs
Trade
Machine - For Trade
Pittsford, NY
